17.8-016, 26 Jan 2017: Based off OSMC commit (
b9120ae19e) and newclock5 (
c19f767aa)
XBMC:
[PVR][guiinfo] Videofullscreen/Musicvisualisation: Direct channel number input (PR:11434, 5 commits, 24 files changed)
[binary-addons] bootstrap: don't filter addons when auto bootstrappin… (PR:11470, 1 commit, 1 file changed)
[Fix] Restore caching for slow plugins Ticket #17211 (PR:11478, 2 commits, 3 files changed)
[settings] restore show EXIF picture information setting (PR:11457, 3 commits, 7 files changed)
[cmake] Only install VideoPlayer fontconfig configuration files on Apple (PR:11451, 1 commit, 2 files changed)
[pydocs] Corrections on the xbmcvfs/file examples (PR:11454, 1 commit, 1 file changed)
[gui] fix container bools (PR:11484, 1 commit, 1 file changed)
[cleanup][windows] linking instructions (PR:11496, 1 commit, 8 files changed)
added: make CFileItemList iterable (PR:11003, 1 commit, 1 file changed)
Align the settings level for the 2 different character set settings (PR:11449, 1 commit, 2 files changed)
Replace raw pointer in CApplication (PR:11514, 1 commit, 2 files changed)
add pycryptodome python module (PR:11477, 1 commit, 10 files changed)
add another overload for begin()/end() (PR:11505, 1 commit, 1 file changed)
Resolution: Do not switch resolutions when in 3D (only refreshrates) (PR:11502, 1 commit, 1 file changed)
[PVR] Fix deadlock (can occure while installing/uninstalling pvr client addon). (PR:11497, 1 commit, 1 file changed)
Replace 3 raw pointers in CApplication with unique_ptrs (PR:11517, 1 commit, 2 files changed)
spelling: transition (PR:11465, 1 commit, 3 files changed)
[Fix] Multiple changes of song rating from player OSD (ticket #17190) (PR:11513, 1 commit, 3 files changed)
Remove CBackgroundPlayer (PR:11512, 2 commits, 1 file changed)
Updated Hungarian strings for XBMC and Confluence (PR:3, 2 commits, 2 files changed)
[PVR] PVR Manager/Clients: Fix stop playback on addon uninstallation. (PR:11515, 1 commit, 2 files changed)
spelling: formatted (PR:11466, 1 commit, 22 files changed)
added: ability to remove add-on settings upon uninstall (PR:11499, 3 commits, 4 files changed)
[PVR][Settings] Remove 'hide connection lost warning' setting and code. (PR:11500, 1 commit, 5 files changed)
[PVR][json-rpc] Fix PVR.(Add|Toggle)Timer. (PR:11506, 1 commit, 3 files changed)
restore the ability to build without python and add cmake option (PR:11467, 1 commit, 12 files changed)
Added Russian translation to the shortcut comment (PR:11260, 1 commit, 1 file changed)
[cmake] git update-index --refresh must be called before using it (PR:11511, 1 commit, 1 file changed)
FIX: [droid] Copy splash to xxxhdpi drawable (PR:11510, 1 commit, 1 file changed)
[cmake] fix libdvdnav build when dvdcss is disabled (PR:11533, 1 commit, 1 file changed)
[guilib] allow more flexible hitrects (PR:11476, 1 commit, 3 files changed)
fixed: context menu manager mess with profiles (PR:11490, 1 commit, 3 files changed)
VideoPlayer: check for vsyncAdjust on every cycle, speed of videoRefC… (PR:11351, 1 commit, 1 file changed)
Modified cpluff to handle utf8 path names to avoid addon failures (PR:11540, 1 commit, 1 file changed)
[droid] fix packaging after Commit:2816efc (4da9e3ff)
inputstream.adaptive:
ServerCertificate / SSD version bump -> 6 (432e6c01)
cleanup CMakeLists.txt (d248490b)
Merge branch 'master' of
https://github.com/peak3d/inputstream.adaptive (8d59790d)
Servercertificate transport (ssd) (6cc3af1b)
sessionid template support (806fbf62)
supporst b template for base64_notuuencoded (30177d1c)
peripheral.joystick:
Added buttonmap for PS4 V2 controller (PR:73, 1 commit, 1 file changed)
pvr.hts:
Some fixes (PR:275, 6 commits, 10 files changed)
Fix CTvheadend:
emuxIsTimeShifting() (PR:277, 1 commit, 3 files changed)
pvr.iptvsimple:
Update README.md (PR:97, 1 commit, 1 file changed)
pvr.mythtv:
4.2.1 (PR:58, 7 commits, 14 files changed)
fix style defect (8ae12371)
sync upstream demuxer (eae59f4e)
Using gmtime_r here was wrong, and caused incorrect hours to display when g_bUseAirdate was set. (afd91eb0)
Revert "WINDOWS: define gmtime_r in tools.h" (7284825e)
Bump version 5.0.8 (8789e2fc)
cleanup pvr api calls (df70b749)
sync upstream demuxer (ac41f384)
fix bad reported bookmark error (69bfc3c2)
sync upstream cppmyth (2.9.3) (ddb17216)
[lang] updated language files from Transifex (36f24189)
moving cmake project to root (4e7ac460)
update dependency mirror (0d409cfe)
silent error when set bookmark failed (f346c10b)
Bump version 5.0.9 (c608a458)
sync upstream cppmyth 2.9.4 (ea2c47d6)
[lang] updated language files from Transifex (dd9947bc)
newclock5:
New commits in this build:
DVDFileInfo: Fix video thumbnail extraction (c19f767a)
Commits no longer in build:
Revert "[settings] remove show EXIF picture information setting" (7715030c)
VideoPlayer: check for vsyncAdjust on every cycle, speed of videoRefClock might have changed (51e9ff2f)
Restore caching for slow plugins (39c1bcc7)
