2016-12-24, 09:12
I have a movie encoded using x265 with PGS subtitles as a MKV file. The subtitles do not show up in Kodi (using v16.1) to enable or disable. It is as if subtitles do not exist. Subtitles appear fine on VLC player.
Some posts on the web suggest that the PGS format of subtitles will not appear correctly and i should download or have subtitles as an external file (which I don't want to do).
http://www.love-media-player.com/mkv-sub...d-in-kodi/
Information on file is as below.
General
Unique ID : 45307215921102726947793493607116448127 (0x2215DA35D5420AAAB51BAC4B6664217F)
Complete name : W:\Video\Suicide Squad.mkv
Format : Matroska
Format version : Version 2
File size : 1.29 GiB
Duration : 2h 2mn
Overall bit rate : 1 505 Kbps
Encoded date : UTC 2016-12-22T21:48:50Z
Writing application : HandBrake 0.10.5 2016021100
Writing library : Lavf55.12.0
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : [email protected]
Codec ID : V_MPEGH/ISO/HEVC
Duration : 2h 2mn
Bit rate : 1 091 Kbps
Width : 1 920 pixels
Height : 800 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.030
Stream size : 959 MiB (72%)
Writing library : x265 1.9:[Windows][GCC 4.9.0][64 bit] 8bit
Encoding settings : wpp / ctu=64 / min-cu-size=8 / max-tu-size=32 / tu-intra-depth=1 / tu-inter-depth=1 / me=1 / subme=2 / merange=57 / no-rect / no-amp / max-merge=2 / temporal-mvp / no-early-skip / rdpenalty=0 / no-tskip / no-tskip-fast / strong-intra-smoothing / no-lossless / no-cu-lossless / no-constrained-intra / fast-intra / open-gop / no-temporal-layers / interlace=0 / keyint=240 / min-keyint=24 / scenecut=40 / rc-lookahead=15 / lookahead-slices=5 / bframes=4 / bframe-bias=0 / b-adapt=0 / ref=3 / limit-refs=3 / no-limit-modes / weightp / no-weightb / aq-mode=1 / qg-size=32 / aq-strength=1.00 / cbqpoffs=0 / crqpoffs=0 / rd=2 / psy-rd=2.00 / rdoq-level=0 / psy-rdoq=0.00 / signhide / deblock / sao / no-sao-non-deblock / b-pyramid / cutree / no-intra-refresh / rc=crf / crf=24.0 / qcomp=0.60 / qpmin=0 / qpmax=51 / qpstep=4 / ipratio=1.40 / pbratio=1.30
Default : Yes
Forced : No
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Color range : Limited
Audio
Format : AC-3
Format/Info : Audio Coding 3
Mode extension : CM (complete main)
Format settings, Endianness : Big
Codec ID : A_AC3
Duration : 2h 2mn
Bit rate mode : Constant
Bit rate : 384 Kbps
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Compression mode : Lossy
Delay relative to video : 27ms
Stream size : 338 MiB (26%)
Title : Surround
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : The same subtitle format used on BDs/HD-DVDs
Language : English
Default : No
Forced : No
General
Format : Matroska
Duration : 2h 2mn
Video
Format : HEVC
Duration : 2h 2mn
Height : 800 pixels
Color space : YUV
Bit depth : 8 bits
Default : Yes
Forced : No
Audio
Format : AC-3
Codec ID : A_AC3
Duration : 2h 2mn
Bit rate : 384 Kbps
Bit depth : 16 bits
Title : Surround
Language : English
Default : Yes
Forced : No
Text
Format : PGS
Language : English
Default : No
Forced : No
