2017-01-19, 03:29
FunimationNOW Kodi Add-on
Before reading further, please note that this plugin is unofficial and is not endorsed or supported by Funimation in any way. If you're interested in helping out with the development, then please just send me a pull request. If you're reporting a bug, make sure you've enabled debugging in both the addon settings as well as in Kodi and attached the log. Feedback and constructive input are of course always welcome.
This plugin was written based on FunimationNOW's API.
Dependencies:
This plugin is will be available in the official Kodi repository and all dependencies will be installed automatically when installed from there. However, if you're installing straight from git, please make sure you've got the following modules installed:
This plugin supports Kodi Jarvis or later. While it may work fine on older versions as well, it is unsupported and you're encouraged to upgrade.
Features:
- Unified UI which works the same as all FunimationNOW applications
- Playback Synch Across all devices
- Queue Synch across all devices
- New FunimationNOW API
- User customizable image quality
- User customizable video quality
- Individual KODI profile support
Known issues:
- getMyRaying() Error: Work around is to rate 1 show using the star rating icon. This will be addressed next update
- Occasional API slowness (Host issue)
- Occasional Errors when reading Queue update (Host issue invalid format returned)
- Occasional Errors when reading Star Rating update (Host issue invalid format returned)
Links:
The old Funimation API has gone off the air today. The updated Add-on is still awaiting a PR. Until then, anyone interested whom runs Kodi 16+ Can manually install it from the Repo.
The new FunimationNOW Add-on should have the same look and feel as the application across any device (Firetv/Xbox/Apple may have a different layout).
The new API can be sluggish at times, and they have recently removed the ability to see what genre is show is under in turn they replaced genres with generic show information.
The new API also has distinct Video quality per show, so there is no real way to determine possible resolutions, so a slider has been introduced for a quality percentage. This means, most videos have 10 bitrate options, usually 7-8 are 720 and 9-10 are 1080.
Image quality is a slider as well. Default is 60% which is approx 70k per image. you can reduce it down to 10 which is about 7k per image or 100 which can be 700k per image.
The new UI was needed due to the API changes. There is no distinct way to get video information without individually running an http request for ever single episode.
Screenshots:
