MKANET
Senior Member
BUMP^
In case, I posted in the wrong forum, I'd really appreciate if someone could tell me the best place to get help for this.
Thanks in advance!
jjd-uk
Team-Kodi Member
I think that's likely to a problem with whatever skin you are using as display of fanart is controlled by the skin, if set there to be no Visualisation do you get the same thing?
any chance to disable ANY fanart/picture overlay while displaying fullscreen visualization? Or some way to change its transparency??
Using Milkdrop2, Kodi 17.1RC1, Estuary skin.
MKANET
Senior Member
Does anyone know what skins I can try similar to Aeon NOX/Aeon MQ that doesn't display the transparent grey squares over visualization addons? I'm currently using Aeon MQ7 for Kodi 17; which, I really like; except for this "feature".
