  • 90
  • 91
  • 92(current)
  • 93
  • 94
  • 319
Mod Estuary MOD V2 - KODI 18 (UPDATED 17/01/19)
New Update 2.7.2 on repository :
• Add Top 250 from IMDb on dialog video info
• Add button to download all Artworks on dialog video info
• Add toggle button on PVR Guide to enable standard colors for genres
• Add setting to pause video during access to extended info
• Add possibility to configure media flags
Image Image
• Change appearance of 'TV Show - Next Aired' addon
Image Image
• Fix fanarts when 'Show video on background' is disable
• Minor changes
• Minor fixes
 Estuary MOD V2
(2017-08-10, 23:29)Guilouz Wrote:
(2017-08-10, 13:24)SharpCoder Wrote:
(2017-08-10, 10:58)Angelinas Wrote: Are you use remote or keybord...or simular ¿
Maybe isue is from device not skin xml
I would assume that if "down" on the controller didn't work everywhere else in kodi but it does bar the custom widgets in question.
But to double check, i tried Kore on my phone, same result, tried my samsung tv remote via CEC, same result, and a spare Rii controller i had laying around, same result.
It's totally strange why it's not working, specifically for me and sure baffles me that's for sure.
EDIT: added video
https://www.youtube.com/watch?v=-JP5f-DIp7M
Very strange, impossible to me to reproduce this issue, I have tested with OSX and LibreELEC on my intel NUC and it's working. Nothing in log file ? Do you use latest Skin Shortcuts addon from Marcelveldt repo ?
here is kodi log https://pastebin.com/2EjZpm2d
i have installed most addons needed by the skin in the nessecary section but librayeditor and marcelveldts repo dont work on it so i installed them from the following.
https://github.com/phil65/script.library...master.zip
https://github.com/marcelveldt/repositor...-1.0.1.zip
(2017-08-10, 13:24)SharpCoder Wrote: I would assume that if "down" on the controller didn't work everywhere else in kodi but it does bar the custom widgets in question.
EDIT: added video
Please join a proper debug log, this one have multiple session with original estuary, estuary mod etc...
 Estuary MOD V2
(2017-08-10, 23:29)Guilouz Wrote: Very strange, impossible to me to reproduce this issue, I have tested with OSX and LibreELEC on my intel NUC and it's working. Nothing in log file ? Do you use latest Skin Shortcuts addon from Marcelveldt repo ?
http://sprunge.us/HKSA
(2017-08-11, 02:21)SharpCoder Wrote: here is kodi log https://pastebin.com/2EjZpm2d
Your debug log it's not full.
You must reset home menu shortcuts to have a clean home menu. Clear your logfile, reboot kodi, configure widgets you want and reproduce issue on home screen. Restart Kodi and join your debug log.
 Estuary MOD V2
2.7.2 is a great update.
Nvidia Shield TV 2015, Sony BRAVIA XBR55HX929, Yamaha Aventage RX-A3050, Dolby Atmos/DTS:X (5.1.4) Front Mains: Jamo C109, Surrounds: Jamo C103, FH/RH: Jamo C93, Center: Jamo C10 CEN and Subwoofer: Jamo J112 SUB
What I like to see in this screen when I hit Media info button, is the year and genre of the movie.
There is also a small bug where the movie aspect ration is not shown.
Is there an option to remove the white border from the banner?
(2017-08-12, 01:27)iMak Wrote: Image
Aspect ratio is correctly shown for me :
It's strange because it's correctly show on library. And I don't have movie with 5:3 aspect ratio to test.
I can do something like this :
 Estuary MOD V2
Guys how put this menu:
Thanks for this update bro!!
(2017-08-12, 07:13)XxKaiserxX Wrote: Guys how put this menu:
In Skin settings / Home menu / Minimize main menu
 Estuary MOD V2
That would be great...
Also in Recently added movies, it would be nice to have the year and genre of the movies...
@Guilouz, can you bring back the "Big Poster" view in the V1 version? I don't know why it's removed in V2, and I tried to use other view types in V2, but not any view type in V2 can be a replacement for it. I use that view type very much.
Another issue, when I was moving focus from one item to another in the widget ("Recently added movies" widget, for example), I found the moving looks like a "jump" now, not that gentle as before, is this expected?
Got instant freeze on exit since a few days
Probably comes from one of the addon used by the skin
Nothing really usefull in the log
Do not freeze on fresh kodi install
Moanbag is in da place!
Year is already present in this view, but Kodi core don't show it on recently added screen.
I do not want to overload this view, all info are on video info screen.
 Estuary MOD V2
  • 90
  • 91
  • 92(current)
  • 93
  • 94
  • 319
Estuary MOD V2 - KODI 18 (UPDATED 17/01/19)17
