  • 2
  • 3(current)
  • 30
Release Catch-Up TV & More
#31
(2018-01-31, 19:48)wwark Wrote: Good Smile
Thanks for the interest of this plugin.
If you want additions or you find some problems don't hesitate to report them !
Wwark.
Thanks, that's so nice of you!
Hi I just wanted to know if someday it would be possible to watch DRM protected video, maybe by using inputstream adaptative like the netflix addon ?
Normally I wiil say yes but it depends of the requirement inputstream adaptative and the version of Kodi (18 not release).
There is a lot of different implementation of DRM (Specific code for each channel) and inputstream adaptive don't support all of them.
We will keep you inform about the progress in the github commit.
Thanks,
Wwark.
Hi Piotr,
Thanks !!!
Yes the last version of Kodi 18 (nightly build) have a new feature.
In this commit on the developpement branch (version 0.1.13b~beta013), I desactivate the feature (git link)
The issue seem to be link to simpleplugin I have to analyze if I have to change some part of the code or ask the developpeur of simpleplugin to fix it.
Wwark
Darrenhill, I will verify the next time if there some ban addons before get my response.
Piotr, can you please remove your log like requested ?
bojan1611, sorry I can't respond on the private message. Most of links proposed in this addon are geolocked like France 2, 3, 4 and 5.
Thanks,
Wwark
Thanks for the removing of the pastebin Smile
Did m6 change something I only got 240p stream that's unwatchable. Sad
Hi mac1202,
Yes unfortunately the stream not protected by DRM are only 240p .... :'(
Meanwhile, we worked on DRM stuff for 6play and MYTF1 on this test plugin accessible here plugin.video.catchuptvandmoretestdrmkodi18
You can install along the principal one. With this test plugin compatible Kodi 18 Beta 2 we have correct quality for M6.
When Kodi 18 will be available (release) we will merge this test plugin to the principal one.
Thanks,
Wwark.
This is awesome thanks you guys.
Edit : work for tf1 can now watch drm protected content. But authentication fail on M6 I suppose it's not yet implemented.
Edit 2 : debug log https://ptpb.pw/BCLD
Hi mac1202,
You need to create an account for 6play and fill login and password in the configuration of the plugin.
With this resource, you will be able to view DRM in M6, W9 ... and live TV also Smile
Good night,
Wwark
Thank you Smile
I already have a 6play account and configured it in the option. But the authentification fail.
Edit : nevermind it work now. I don't know why when I enter my password in setting it's not properly saved. Directly editing the config file fix it.
We proposed now a repo for the plugin Test DRM details here Add-the-official-repository
We add also DRM capabilities for Quest OD (catch-up), Quest (Live TV) and Quest Red (Live TV)
Thanks,
Wwark
A new update of the plugin Kodi 18 Test DRM is pushed of our repository.
This new update contains the catchup-tv of UKTVPlay channels (Dave, Really, ...).
Since few days, these replays propose just DRM protected content.
Thanks,
Wwark.
I want to add a favourite to the French replay section of the plugin. However when I add it, the favourite in favourites.xml looks like this:
html:
ActivateWindow(10025,"plugin://plugin.video.catchuptvandmore/?action=generic_menu&item_id=fr&item_path=%5b%27root%27%2c%20%27channels%27%2c%20%27fr%27%5d&item_skeleton=%5b(%27tf1%27%2c%20%27replay_entry%27)%2c%20(%27france2%27%2c%20%27replay_entry%27)%2c%20(%27france3%27%2c%20%27replay_entry%27)%2c%20(%27canalplus%27%2c%20%27replay_entry%27)%2c%20(%27france5%27%2c%20%27replay_entry%27)%2c%20(%27m6%27%2c%20%27replay_entry%27)%2c%20(%27c8%27%2c%20%27replay_entry%27)%2c%20(%27w9%27%2c%20%27replay_entry%27)%2c%20(%27tmc%27%2c%20%27replay_entry%27)%2c%20(%27tfx%27%2c%20%27replay_entry%27)%2c%20(%27nrj12%27%2c%20%27replay_entry%27)%2c%20(%27france4%27%2c%20%27replay_entry%27)%2c%20(%27bfmtv%27%2c%20%27replay_entry%27)%2c%20(%27cnews%27%2c%20%27replay_entry%27)%2c%20(%27cstar%27%2c%20%27replay_entry%27)%2c%20(%27gulli%27%2c%20%27replay_entry%27)%2c%20(%27franceo%27%2c%20%27replay_entry%27)%2c%20(%27tf1-series-films%27%2c%20%27replay_entry%27)%2c%20(%27lequipe%27%2c%20%27replay_entry%27)%2c%20(%276ter%27%2c%20%27replay_entry%27)%2c%20(%27numero23%27%2c%20%27replay_entry%27)%2c%20(%27cherie25%27%2c%20%27replay_entry%27)%2c%20(%27la_1ere%27%2c%20%27replay_entry%27)%2c%20(%27bfmbusiness%27%2c%20%27replay_entry%27)%2c%20(%27rmc%27%2c%20%27replay_entry%27)%2c%20(%2701net%27%2c%20%27replay_entry%27)%2c%20(%27tfou%27%2c%20%27replay_entry%27)%2c%20(%27xtra%27%2c%20%27replay_entry%27)%2c%20(%27lci%27%2c%20%27replay_entry%27)%2c%20(%27lcp%27%2c%20%27replay_entry%27)%2c%20(%27rmcdecouverte%27%2c%20%27replay_entry%27)%2c%20(%27stories%27%2c%20%27replay_entry%27)%2c%20(%27bruce%27%2c%20%27replay_entry%27)%2c%20(%27crazy_kitchen%27%2c%20%27replay_entry%27)%2c%20(%27home%27%2c%20%27replay_entry%27)%2c%20(%27styles%27%2c%20%27replay_entry%27)%2c%20(%27comedy%27%2c%20%27replay_entry%27)%2c%20(%27publicsenat%27%2c%20%27replay_entry%27)%2c%20(%27histoire%27%2c%20%27replay_entry%27)%2c%20(%27tvbreizh%27%2c%20%27replay_entry%27)%2c%20(%27ushuaiatv%27%2c%20%27replay_entry%27)%2c%20(%27studio-4%27%2c%20%27replay_entry%27)%2c%20(%27irl%27%2c%20%27replay_entry%27)%2c%20(%27seasons%27%2c%20%27replay_entry%27)%2c%20(%27comedie%27%2c%20%27replay_entry%27)%2c%20(%27les-chaines-planete%27%2c%20%27replay_entry%27)%2c%20(%27golfplus%27%2c%20%27replay_entry%27)%2c%20(%27cineplus%27%2c%20%27replay_entry%27)%2c%20(%27infosportplus%27%2c%20%27replay_entry%27)%2c%20(%27gameone%27%2c%20%27replay_entry%27)%2c%20(%27francetveducation%27%2c%20%27replay_entry%27)%2c%20(%27gong%27%2c%20%27replay_entry%27)%2c%20(%27francetvsport%27%2c%20%27replay_entry%27)%5d&module_name=None&module_path=None&window_title=France",return)
It has all the channels listed in it. The problem is that I want to avoid to have to maintain that list whenever the plugin adds or remove a channel.
Is there a way to create a link to the French replay section without listing all the channels in the link?
  • 2
  • 3(current)
  • 30
Catch-Up TV & More1
