  • 6
  • 7(current)
  • 8
  • 9
  • 30
Release Catch-Up TV & More
#91
Undecided
Do you have the complete log with the complete URL please?
Don't worry, I've done a reboot and this has worked now. Confused
Hum ok ... The main thing is that it works now Big Grin
(2019-03-25, 10:39)sy6sy2 Wrote: Hello @dongus,
Very strange if the installation went well...
What method did you use in order to install the Addon? With our official repo like described here: https://catch-up-tv-and-more.github.io/installation/ ?
You can try to enable Kodi debug log en reinstall the Addon in order to have more details.
Thank you.
I went to the repo on a computer, copied the zip file over samba into the downloads folder on my Kodi machine. I then installed via zip file.
Ok. I'll try and get the log.
Hi @dongus
What you installed is not the video plugin Catch-up TV & More BUT the repository addon that allows you to install Catch-up TV & More from the Kodi add-on library ;-)
Hi eveyone,
I try to nstall Catch-UP tv last release and when i try update to version 0.2.4 nothing happen.
Im on kodi 17.6 on a Raspberry Pi 3 B+
But if i do the same on the official kodi repository it work (but it's not the same version)
And with the kodi official repository version, french direct tv don't work kodi say me ("system error check your logs")
I live in France By the way
Hi deps,
Are using the procedure given here https://catch-up-tv-and-more.github.io/fr/installation/
Maybe you can try to remove the add-on installed from the Kodi repo in order to do a fresh install with the given tutoriel?
Also, can you provide the debug log? (You need to enable the debug log in Kodi settings)
(2019-03-30, 16:07)sy6sy2 Wrote: Hi deps,
I already remove the add on and try to install directory from the repository but the sme thing when i clic to install nothing happen (download dosn't start)
Where i can find the debug log file?
I think it was just a coinsidence but a new version is available now, so i think that the repository was in update that's why that dosn't work.
Because a new version is now available (and it work)
so my issue is fixed
Oh yes, Wwark just released a major update of the plugin with the built-in Kodi Live TV support over M3U files (a step by step tutorial coming soon, but at the moment we only have a README to enable this feature : https://github.com/Catch-up-TV-and-More/...LIVE_TV.md).
It's strange that the release caused this issue .. don't know ... Anyway, if it works for you this is the main ;-D
Thank you.
Hi. On closer inspection only the repo added installed successfully. The add-on install fails because it can't install a dependency. Looking at the log, that dependency may be youtube-dl.
Relevant log section here: https://paste.kodi.tv/puheyamonu.kodi
Can upload full log if required.
Thank you.
Hi Dongus,
You seem to have issue to install all dependancies required by our plugin to work.
Which version of Kodi did you use ? Do you have the official Kodi repository in your kodi instance?
The full log will be helpfull
Thanks,
Wwark.
Thank you.
Hi Dongus,
Thanks,
Wwark.
I installed a fresh version of LibreElec running Kodi 17.6. I then used the backup addon to restore my addons from OpenElec.  Yes I have the Kodi repo (Team Kodi ver 2.5)
Full log here: https://paste.kodi.tv/ekidoniguf.kodi
@dongus - you also have banned addon (wiki) repos installed, meaning your device is unsupported here.
Please see the forum rules (wiki) that you accepted and agreed to abide by when you signed up here for more details.
|Banned add-ons (wiki)|Forum rules (wiki)|VPN policy (wiki)|First time user (wiki)|FAQs (wiki) Troubleshooting (wiki)|Add-ons (wiki)|Free content (wiki)|Debug Log (wiki)|
Kodi Blog Posts
  • 6
  • 7(current)
  • 8
  • 9
  • 30
Catch-Up TV & More1
