Hi, cannot play any Dutch live TV channel as they all terminate with 'Index out of Range' errors. I've tried it with the latest Catch-UP 0.2.2 version from the standard Kodi repo and also tried it with the latest beta3 version for the Catch-UP repo. The logfile has been uploaded and an email with the link has been sent to the requested gmail address.
I think the problem can easily be reproduced as it only happens with the Dutch live channels. Watching Dutch catch-up channels do not give any problems. Anybody else have seen the same problems?
I tried to install on Matrix but no luck.
Do I have the right version, 0.2.22 beta 10
I just noticed You tube DL says not available
Greetings,
Side note: sorry for replying to myself, but I don't seem to be able to edit my own posts.
Anyway I was wondering if it was possible to limit the live stream used quality for channels when addon is used in combo with IPTV Simple?
On my Rpi3, anything bellow or equal to 720p plays smoothly, however, 1080p does not.
I looked into the options of addon and all I could find was BEST|DEFAULT|DIALOG which does not help.
I know some channels broadcast using different streams because at first when testing I had set a BW limit in OS to 1024 kbps which resulted into displaying most of channels in SD mode. I have lifted this BW limit and it resulted in most of the channels switching to 720p and some to 1080p.
But I dont seem to be able to make any preference about this.
Of course if channels only streams in 1080p not much we can do here, but I was wondering if there was somewhere a setting to 'limit' quality for live streams like there is for downloading files for example.
Thank you very much.
Regards.
