  • 13
  • 14
  • 15(current)
  • 16
  • 17
  • 29
OSMC announced new Vero4k, opinions?
What's posted there is quite recent. Use of ppmgr seems to be completely removed in v18. In theory, it can be re-added, but this may be subject to change.
(2018-03-12, 01:45)TheShoe Wrote: is 3D still coming? recent posts at osmc seem to indicate because the work would be undone by kodi18 that it is now dead. that is a shame if so.
Why not release for Kodi 17 while working on a new solution for 18? It was more than teased as coming.
 Agreed, this is the reason I went with the Vero 4K.
Box 1: ODroid N2+ 4GB
Box 2: Intel NUC D34010WYK (Windows afedchin's Krypton MVC Build)
Box 3: Vero 4K
RIP schimi2k | I miss you buddy :(
putting it on ebay if this is the case.
sam - please be upfront and honest here. it is a fine device. but i invested because you personally said it was coming. i have no need for it otherwise
(2018-03-10, 17:58)Sam.Nazarko Wrote: As always: thanks for the review and feedback. We'll keep supporting and improving this device with regular updates for a long time yet.
Sam
Nicely thought out additions and extra usability features you have implemented there Sam on the Vero 4K. So good I had to borrow some of them for the LE C2 Wink
In reality all you need for most 4K HDR users, ones without restricted 4:2:2 only projectors is a Kodi GUI user setting of 444,10bit or 444,12bit
I'm already using a Kodi GUI user selectable 422,10bit on the LE U9 with the newer AML Linux Kernel.
HERE is the patch I'm originally using for Kodi Krypton GUI colorspace settings.
Note I cannot get the various 444,10bit options to string parse properly in Krypton. I end up with a greyed out Krypton user settings option.
You may have more luck and skills to spot an obvious error.
(2018-03-14, 02:42)wrxtasy Wrote: Nicely thought out additions and extra usability features you have implemented there Sam on the Vero 4K. So good I had to borrow some of them for the LE C2 Wink
Hi wrxtasy. Can you please point me to the LE U9 build mentioned above. THX
https://forum.libreelec.tv/thread/5848-8...#post84350
Works really well. Excellent work by @wrxtasy.
Sam
 Glad to hear these improvements are beneficial for other users.
We'll fix the green screen issue imminently. but the newer AML drop will lead to disappointments for some users I suspect. While I haven't followed LE community builds in detail, I wouldn't be surprised if they revert back based on our internal evaluation. It's completely unsuitable for HDR, which is probably enough alone to warrant not using it.
Sam
@Sam.Nazarko : Do you know whether the below statement from narmstrong is correct. If it is, it may explain the banding/flicker issues that some users have reported.
Quote:Found the relevant quote from @narmstrong at Baylibre:
S912 has a 10bit pipeline, s905x has only a 8bit to 10bit converter right before the hdmi controller
https://forum.libreelec.tv/thread/9759-c...#post84351
I think Neil refers to P_VPU_HDMI_FMT_CTRL, which is used to control rounding and dithering. As you can see from [1] the values are different for GXL and GXM.
Both S912 and S905x will obviously engage 10-8bit dithering when CD is < 10-bit.
12-10 bit dithering is used on S912, but not on S905x. It's unknown if this works properly yet.
We fixed flickering but now we get banding. I have added [2] so we can now poke the regs during playback and see how we can improve this.
With [3], we should also now be able to decouple the colour space and HDR output (which has been a mistake from AMLogic for some time).
We have to poke at some of this because the docs either aren't there; or contradict some of our experiences.
[1] https://github.com/osmc/vero3-linux/blob...hw.c#L1975
[2] https://github.com/osmc/vero3-linux/comm...f273aec6b6
[3] https://github.com/osmc/vero3-linux/comm...2524149d29
Hey guys sorry for that basic question, but I don't find a simple answer to that:
Does OSMC run a Kodi fork or the "normal" Kodi? So will I be able to use all addons and skins I can use in Kodi, too? (aside from performance limitations given by the hardware)
afaik and use... is the "normal" kodi
20:44:57.481 T:4075270736  NOTICE: Starting Kodi (17.6). Platform: Linux ARM (Thumb) 32-bit
20:44:57.481 T:4075270736  NOTICE: Using Release Kodi x32 build (version for Vero)
20:44:57.481 T:4075270736  NOTICE: Kodi compiled Mar 12 2018 by GCC 6.3.0 for Linux ARM (Thumb) 32-bit version 4.9.30 (264478)
20:44:57.481 T:4075270736  NOTICE: Running on Open Source Media Center 2018.03-2, kernel: Linux ARM 32-bit version 3.14.29-69-osmc
20:44:57.481 T:4075270736  NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
20:44:57.481 T:4075270736  NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
20:44:57.481 T:4075270736  NOTICE: ARM Features: Neon disabled
20:44:57.481 T:4075270736  NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
20:44:57.481 T:4075270736  NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
20:44:57.482 T:4075270736  NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
20:44:57.482 T:4075270736  NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
20:44:57.482 T:4075270736  NOTICE: special://envhome/ is mapped to: /home/osmc
20:44:57.482 T:4075270736  NOTICE: special://home/ is mapped to: /home/osmc/.kodi
20:44:57.482 T:4075270736  NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
20:44:57.482 T:4075270736  NOTICE: special://logpath/ is mapped to: /home/osmc/.kodi/temp
20:44:57.482 T:4075270736  NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
20:44:57.482 T:4075270736  NOTICE: Local hostname: osmc
20:44:57.482 T:4075270736  NOTICE: Log File is located: /home/osmc/.kodi/temp//kodi.log
BHH
HDConvertToX, AutoMKV, AutoMen author
Same add-ons / skins etc. The only slightly more limiting factor is screensavers / visualisations as we have a GLES windowing system.
Is 3D effort dead?
(2018-03-22, 00:52)hdmkv Wrote: Is 3D effort dead?
 Not that I recall?
  • 13
  • 14
  • 15(current)
  • 16
  • 17
  • 29
OSMC announced new Vero4k, opinions?4
