2018-11-15, 17:52
Would I be able to get static ip via this on the box? : https://www.noip.com/support/knowledgeba...on-ubuntu/
(2018-12-13, 04:58)starbudder Wrote: Just wanted to give a "thumbs up" for the Vero 4k+.. Have had it in operation for over a week and I am not disappointed with its performance.Thank you for your kind words.
I am only using it for my extensive library of 1080P movies at this time. It handles both the video and audio formats as advertised.
It is replacing a failing HTPC which is over 10-years old, so I am definitely saving on space, electrical operation cost and a higher HTPC replacement / upgrade cost. I have a 4k FTV stick as well but the Vero handles the various audio and video aspects better. The 4k FTV will stay for for my Amazon Prime viewing..
Great support from Sam as well!
(2018-12-13, 05:35)KillroyWasHere Wrote: What's the timeline for adding support for MaxCLL and MaxFALL HDR metadata?Hi,
Also, does the Vero 4k+ properly play 24bits and higher-than-48kHz FLAC or LPCM audio files? The Shield and all other Android devices are limited to 16bit 48kHz.
(2019-05-05, 04:02)Temujin Wrote:DVD/Blurays/UHD?(2019-05-05, 04:00)Edworld Wrote: I have a Mediasonic ProBox HF2-SU3S2 4 Bay and I am thinking of connecting it to the vero 4k using usb 2.0. Will this work or will I encounter some type of issues?I'm using two of those without issues though a USB hub attached to the Vero
