  • 22
  • 23
  • 24(current)
  • 25
  • 26
  • 29
OSMC announced new Vero4k, opinions?
(2019-06-01, 13:34)Edworld Wrote: Has anyone experienced the unit freezing after pressing pause? Last night I was watching a movie and paused for a snack, when I cake bsck, I couldnt continue watching the movie, had to unplug the unit.
vero 4k plus with May 5.1 update
thanks
The may update actually resolved this issue for me.
You'll get better support if you head to their forums
https://discourse.osmc.tv/c/help-and-support/vero-4k
thanks
Not this issue specifically, but the May update did break the audio offset function for me and introduced a slight lip sync issue.
My Theater: JVC X790R + Peerless PRG-UNV | 120" CineWhite UHD-B Screen | KODI Omega + PreShow Experience | mpv | madVR RTX 2070S | Panasonic UB420 | Denon X3600H @ 5.2.4 | 4 x ADX Maximus w/ Dayton Audio SA230 | 3 x Totem Tribe LCR + Mission M30 Surrounds + SVS PC2000 + Monolith 15 | 40" HDTV w/ MeLE N5105 + MoviePosterApp | 40TB Win10 SMB Server over Gigabit Ethernet
thanks
I ve been trying to get a password to ask on their forum for more than a couple of weeks and still waiting...
thanks
Really? That's odd...well, I'm sure Sam will be around in this thread shortly to help with that. Help over on the forums is usually pretty good. Sorry you're having a tough time.
thanks
I've looked in to this.
Your inbox is blocking emails from us (AT&T RBL is being a pain).
I have PM'd your password. I advise changing it as well as the associated email account, because you won't be able to get emails from us, such as password reset otherwise.
Sam
(2019-05-31, 21:46)Skank Wrote: Any chance for google assistant support inside kodi?
There's a GitHub project somewhere that has some basic integration, but this isn't something that's part of Kodi as standard on non Android platforms.
Sam
Sam
mm Undecided
i thought it was included in leia first
Sam
mm Undecided
No -- it's not part of Kodi. Android has some Google Voice support.
Sam,
Trying to install this skin https://github.com/Funkd/ScopeNox/releas...x.1.23.zip
Version 1.23 i get dependencies error on vero 4k
however skin maker, doesnt get that error on latest leia build
Any ideas?
(2019-06-11, 17:40)Skank Wrote: Sam,
Any ideas?
It depends which version of OSMC and Kodi you are using.
Have you checked that the add-on is compatible with the version of Kodi?
Also go to Settings and refresh the repository
Sam
Any ideas?
Sam
OSMC is using leia 12.3 (latest)
skin also uses 12.3
gonna try with refresh repository, thats in settings of kodi?
Any ideas?
Sam
skin also uses 12.3
Yes.
The latest version of Kodi is v18.
Sam
(2019-06-11, 17:48)Sam.Nazarko Wrote: It depends which version of OSMC and Kodi you are using.
Sam
skin also uses 12.3
Yes.
Sam
MM
i did a clean install of latest osmc
so now that i am thinking, a refresh repository is actually overdone? I mean, it wont help, since its a clean install?
(2019-06-11, 17:50)Skank Wrote: OSMC is using leia 12.3 (latest)
skin also uses 12.3
Yes.
Sam
MM
It's worth a go..
Does the Vero4K support mounting multiple hard drives (with a USB hub/Multi-bay enclosure) ?
  • 22
  • 23
  • 24(current)
  • 25
  • 26
  • 29
OSMC announced new Vero4k, opinions?4
