(2017-03-04, 20:21)Edworld Wrote: This skin is very nice, noticed that you dropped the blue theme.
There is only a couple of things I can think of:
Adding the popcorn to the ratings section ( you have tomatoes, metacritic and IMDB)
and maybe adding an Info icon next to artwork downloader in case you want to add a popup box with additional info like critics consensus, awards, and everything skinhelper provides.
Yeah I only dropped the blue colour theme because I added skinhelper's colour selection, so I felt it wasn't necessary as all it did was change the highlight colour anyway. Leaving the colour themes for changing things like dialogs (there is a light dialog theme) so you can still mix and match colour highlight with colour theme. There will also be a flat texture theme that removes gradients when it goes to repo.
I assume the popcorn is for themoviedb ratings as that is the only ratings I could see from skinhelper that I was missing. Added on git.
I also added some extra info in video info - budget, box office, awards and consensus
(2017-03-04, 23:03)Edworld Wrote: Jurialmunkey:
Can you make the title of the movie scroll? and maybe reduce the space between flags
Done and done.
(2017-03-05, 00:05)mark2112 Wrote: Really nice. Really fast to navigate. There is no way to change the style of the widget and it just chooses a style at random that often doesn't suit. Could you add an option to choose the widget style (square, landscape etc)
Can you tell me what addons / paths etc. are not giving the right view type?
The views are supposed to adapt based upon the content type -- landscape for tvshows and videos, posters for movies, square for music and addons. I want to check whether its something wrong with my code or if it is just addons not setting content type correctly (which, if the case, should be taken up with addon author).
(2017-03-05, 00:24)Jönke Wrote: Will i be able to add and remove menu items from home ? I use Spotify addon and has no use of Music as a example. So can i add "Spotify" to start Spotify addon ?
Yep the skin uses skin shortcuts, so you can setup the menu however you like.
