Media info not showing in fanart view
Hi!
I'm using OpenELEC 7.0.1 (Kodi 16.1) on a Raspberry Pi2 with the Confluence skin.
Everything works except for a little problem.
I use the "fanart" view for my video library and in some views there is no metadata (info panel) for the movies.
For instance in the "Recently added movies" or when browsing the library from "Film" everything works and the fanart view shows the info panel.
But sometimes I like to browse by folder and there the fanart view just shows the poster and the fanart without the panel for the information. In the same location all the other views (media info 1, media info 2, media info 3) show (for the same files!) the info panel perfectly.
I also tried to tweak the option about showing the information in fanart view but it has no effect.
What can I do?
Thank you very much!
Media info not showing in fanart view0
