Hello sg1102,
How did you solve the issue :
UNABLE TO MAKE A WEB REQUEST. YOUR SERVER RETURNED A 400
2018-04-22, 19:48
(This post was last modified: 2018-04-26, 01:03 by bzellinger.)
Thanks for the hard work. I just wanted to chime in and let everyone know that this also works with Cortana. You might want to change the topic to reflect that.
400 is a bad syntax error. What I was doing wrong was entering just my password in the body field of ifttt instead of {"token":"mypassword"} where mypassword is the password I setup in the last line of the .env file in glitch. Hope that makes sense!
Thanks for all the hard work that has been put into this. It works great. The only thing I'm struggling with is playing tv series. Just wondering if anyone can answer me this.
I have my tv series store in the library under the Series name and then individual seasons. For example:
Downton Abbey (folder)
Season One (sub folder)
Individual files for each episode (eg Downton Abbey S01 E01) etc
Season Two (sub folder)
Individual files for each episode (eg Downton Abbey S02E01) etc
If I want to play a specific show/season and episode - for example Downton Abbey Season Four Episode Two what code do I use. I see from the instructions that I can use the following for TV showsSay a phrase with a text ingredientKodi play an episode of $YOUR_NODE_SERVER/playtvshow?q={{TextField}}This works if I say play an episode of Downton Abbey - then it plays a random episode.
I thought I would try the other code listedSay a phrase with both a number and a text ingredientKodi play $ episode #YOUR_NODE_SERVER/playepisode?q={{TextField}}&e= {{NumberField}}but if I say Kodi Play Downton Abbey Season Four Episode two it doesn't seem to pick up the right season and episode am I missing something.
Any advise would be appreciated.
I was going to try running this on my Synology NAS but did some research on installing node.js on my Nvidia Shield since I did not want to have my NAS powered on 24/7. Happy to say it works on the Shield since it is very low powered and no need to have drives spinning. I was a bit worried since after the npm install there where some errors but I proceeded anyway and it worked out.
Sukre
Junior Member
Hi, can this be integrared shit homeassitant? Like even only the “node” part ?
First of all, thanks for making this. I have a couple of questions, Im trying to use this with docker on libreelec. Do I still need to point my webserver 8080 to the internet with me hosting this on docker? My VPN on libreelec blocks this and was hoping that self hosting would remove the need for this. Also what address would I use for IFTTT? All the guides point to the glitch address but im not using glitch, so what would the address be instead for example play/pause? Any help would be great, I haven't seen anyone using this with docker yet.
Hi All, kinda linked to the above.
I was wondering if there was a way of doing this without the connection to the external IP?
If the Google Home and the Media PC are on the same WIFI LAN?
2018-08-11, 00:45
(This post was last modified: 2018-08-14, 08:00 by Dubs2.)
Hey, thanks for this! Great work.
Edited: I'm an idiot. I misread some stuff.
2018-08-31, 14:40
(This post was last modified: 2018-08-31, 15:31 by Davidsilva.)
please delete ive fixed it now
I tried to clone the project into glitch, but am running out of options after thag. Two things:
A) How do I find the option to set the project to private?
B) I cannot find the env-file in the project files. Is it located elsewhere?
I got it all working on a looal server. Awesome stuff. 😎
The only thing that doesn't work are the playlists. I checked my Kodi logfiles and Kodi doesn't receive a call.
Anyone who got playlists to work?
Hi..I am not a tech guy and I dont have a static IP and I Have absolutely no idea about coding. In Env edit I put in kodi, kodi and kodi for auth token as well. in IFTTT as well for that 'body", i put kodi instead of my connection token..is the right thing to do? in IFTTT the task is successful. When I shout the comment hey google kodi play wreck it ralph....it says ...i dont see any chormecast or cast enabled TVs enabled in your account....what wrong am I doing pls..
