2018-12-02, 05:24
Just to clarify...I have my kodi on my desktop which is connected to my TV. and since i am making all the changes and testing at the same time, i guess not having a static IP shoulnt make a difference
http://192.168.5.123:8082/jsonrpc?request={"jsonrpc":"2.0","id":1,"method":"Player.playpause","params":{"playerid":1}}
={"error":{"code":-32099,"message":"Bad client permission."},"id":1,"jsonrpc":"2.0"}]
docker build --tag omertu/googlehomekodi .
Sending build context to Docker daemon 574 kB
Step 1/17 : FROM node:alpine as builder
Error parsing reference: "node:alpine as builder" is not a valid repository/tag: invalid reference format
(2018-12-24, 19:34)bkagan Wrote: I'm looking for some assistance.
I have some of the pieces working but not the whole deal.
I'm good with the server node running and IFTTT configurations to Google home.
My issue is sending commands to the KODI json piece.
I run this command in my web browser:
and I get this response:Code:http://192.168.5.123:8082/jsonrpc?request={"jsonrpc":"2.0","id":1,"method":"Player.playpause","params":{"playerid":1}}
Code:={"error":{"code":-32099,"message":"Bad client permission."},"id":1,"jsonrpc":"2.0"}]
It does prompt me for a userID and password (chrome doesn't but Firefox and IE do) but the PAUSE command does not pause the playing video.
Is there a setting in Kodi that I'm missing?
I CAN play videos on the kodi from the Browser.
Under services> I have both "Allow remote control from applications on this system" and "Allow remote control from applications on other systems" ENABLED
the IP and Port are correct on the kodi machine and so is the userID:password
Using Kodi 18.0 rc3 on windows 10
latest googlehomeKodi from OmerTu fork (also on a windows 10 machine
Nodejs 10.14.2 (includes npm 6.4.1)
thanks
(2019-09-29, 00:13)captainfearless Wrote: I’ve been enjoying this tool set up using Cortana, and all of a sudden Cortana won’t talk to IFTTT.Sorted, i unknowingly had 2 live outlook accounts!
I’ve run Windows 10 updates, turned off VPN, anti virus etc, created a new IFTTT account to reconnect to Cortana, checked Cortana is signed in.
I have only 1 Microsoft account and email address so i can‘t think what might have changed.
I’d be grateful for any suggestions.
