When browsing files in a directory containing a broken symlink, the following files doesn't show.
OSX's "Alias" doesn't seam to be affected.
Possibly this is a *nix-problem...
Thank's for the good job!
topfs2
Team-Kodi Developer
How do you mean? if we have a nbr of files in a folder say a - d and a symlinked e.
When "e" is broken a - d shows but not e?
Or does some of the other ones also dissapear?
if the latter could you post an easy way to reproduce.
topfs2
Team-Kodi Developer
But if you remove the source, it doesn't link to anything. The if this is a movie it wouldn't play because it isn't on the HD anymore...
I still haven't gotten why it should show it. when a symlink gets broken it's usually because linux can't access the file, and if linux can't acess it then XBMC wouldn't either. Thus the file wouldn't play anyway
At me when the symlink works I get
a
b
c
d
e
Inside xbmc, if I delete e only
a
b
c
Gets shown, these are the only files which actually work.
Does only d show at you when you delete e? even if a b c are still present?
If you have problems please read
this before posting
Always read the
XBMC online-manual,
FAQ and
search the forum before posting.
Do not e-mail XBMC-Team members directly asking for support. Read/follow the
forum rules.
For troubleshooting and bug reporting please make sure you
read this first.
"Well Im gonna download the code and look at it a bit but I'm certainly not a really good C/C++ programer but I'd help as much as I can, I mostly write in C#."
topfs2
Team-Kodi Developer
I moved you back because I don't run XBMC osx but it is a bug if it does what you are describing. Works in linux though.
this before posting
Always read the
XBMC online-manual,
FAQ and
forum rules.
read this first.
