2017-06-03, 23:58
(This post was last modified: 2017-06-04, 00:00 by JCreeny.)
17.3 on a Xiaomi Mi Box android
There are multiple attached hard drives off a hub.
All are shown correctly by their volume label but when you open 3 of them they have the same folders as one of the drives.
Any thoughts?
The drives have movie folders by year, 2013, 2014 etc.
One of the drives has 2012, 2013 & 2014.
When I look at the media source the volume labels are correct but when I open the drives three show 2012, 2013 & 2014.
So presumably it is physically seeing the drives as separate entities but confusing the contents of three of them.
When you say "hub", do you mean a USB hub?
Correct, it can be powered or unpowered - 7 port.
The Xiaomi is seeing all 5 connected drives and correctly displaying their volume labels
So Libreelec does not have this issue? Had thought of running it anyway.
Libreelec will mount hard drives all day for fun.
But as I say AFAIK it's not possible to stick it on your box.
Thanks, will check it out.
