2017-06-11, 18:37
Raspi b+
OpenElec + Kodi 15.2 (auto boots into kodi)
Im giving my old raspi to a friend and I'm fairly sure they dont have wireless keyboard to use.
I've been looking for a while on how you could putty into the raspi and change the wifi settings there?
I got as far using connmanctl, but it seems to suggest you put the password in on boot - which wont work here as the os auto boots into Kodi 15.2. I have looked into how to disable this but because I can't remember the exact setup I have here (did the install year+ ago) im not sure which tutorial to follow.
If there is any way around this, then I will lend then my usb keyboard to set it up, however I am hoping this is doable via terminal.
Any information would be greatly appreciated
Cheers
Cheers
