Hello,
I would like to put a dot before Media source (Dvd) in renaming files.
How can I do it?
By the example
Frantz (2016).Bluray.iso
Thanks in advance
just put a dot before it in the renamer template?
$T ($Y).$S
tinyMediaManager - THE media manager of your choice - available for Windows, macOS and Linux
Help us translate tinyMediaManager at
Weblate | Translations at 66%
Found a bug or want to submit a feature request? Contact us at
GitLab
myron
Posting Freak
works for me.
The dot is there
Do you mean a space BEFORE the dot?
Because that comes from your pattern:
If no 3D tage is set, $3 will be empty [], and is removed afterwards.
that leaves us with "$T ($Y) {[$K]} .$S" and there will be a space before dot
myron
Posting Freak
try "$T ($Y) {[$K] }[$3].$S"
(space inside optional tag)
would assume that
"$T ($Y){ [$K] }{ [$3] }.$S"
is even better
GitLab
