I'm on Windows 10. It's a 3D SideBySide Bluray ISO. You know, the discs with 2x M2TS files (left and right eye) and the combined SSIF file in the BDMV/STREAM/SSIF folder.
It was not fair to start with this one, I know.
I'm on the latest nightly. What happened to handling the image cache? Now do I have to run rebuild image cache command manually after clear it? I think it used to rebuild it just by scanning movies.
It's working again.Thanks for the quick fix!
updated build
omdb api scraper is now useable by all tinyMediaManager users with a throttling (10 calls / 15 seconds)
+ added mediainfo 0.7.98
- removed the RottenTomates scraper because this service is no longer available for public usage
tinyMediaManager - THE media manager of your choice - available for Windows, macOS and Linux
Help us translate tinyMediaManager at
Weblate | Translations at 66%
Found a bug or want to submit a feature request? Contact us at
GitLab
