  • 109
  • 110
  • 111(current)
  • 112
  • 113
  • 130
Release Embuary Skin
(2019-10-15, 14:00)sualfred Wrote: That's all I can say. As far as I know TVH has to be at least version 4.3
My version of TVH is 4.2.6-7 under libreelec. I thought this was the latest version released? There are no updates under the addon... So any artwork for the recording folder isn't local or from online its from the EPG thumbnails?
Yes, it's from the EPG not from the recording itself. 4.2 is stable while 4.3 is not. But to be honest, TVH is like Debian -> the stable is always far behind. It's save to switch to 4.3. But I cannot tell you how to do it in LE. I'm using Windows and Android as OS.
Main: Lancool II Mesh  - Ryzen 9 5900x - MSI x570 Unify - Zotac RTX 3080 AMP HOLO - 32GB Trident Z Neo 3600 CL16 -  EVO 960 M.2 250GB / EVO 940 250GB / MX100 512GB /  Crucial P1 2TB / WD Blue 3D Nand 2TB
Sound: Saxx AS30 DSP - Beyer Dynamic Custom One Pro
TV: Nvidia Shield 2019 Pro- Adalight 114x LEDs - Sony 65XG9505 - Kodi / Emby - Yamaha RX-V683 - Heco Victa 700/101/251a + Dynavoice Magic FX-4
Server: i3 Skylake - 8GB - OMV4 - 22TB Storage
Hi on the latest version of the skin when selecting music it does not go to full screen even though that option is checked
Have not changed anything for this and works here as expected. Note: It only go to fullscreen once. If playback is already in progress and you back out to the menu to select another song it won't do it again.
A log is might be helpful.
Great skin!
Is there any way to have a TV show Playlist that plays rather than show the different episodes in a widget in hub? I have some sitcoms that I just like to watch random episodes.
I have found a way to do this as a menu option. But would like to have this as a widget.
Not possible.
No problem! Thanks anyway! Still an awesome skin. Have been using amber for the past 5 years and wanted a change.
(2019-10-20, 10:58)jpc0480 Wrote: No problem! Thanks anyway! Still an awesome skin. Have been using amber for the past 5 years and wanted a change.
I have to also say: absolutely great skin. I use it without emby and still it is phenomenal.
One thing I would like to see is some support for Special Features (maybe using the Special Features AddOn). It would be fantastic to see on the info page of a movie that there are and which specials there are and maybe also on widgets and lists some kind of badge showing that there are specials...
I do not know if this is possible and it is for sure a "nice to have" but it would be great anyway...
Not possible and there is no space left in info screens for a third party addon that is not used by a lot of people.
(2019-10-27, 18:55)sualfred Wrote: Not possible and there is no space left in info screens for a third party addon that is not used by a lot of people.
no problem, as I said an absolute "nice to have" and not more Wink
I'm on 18.4 fresh. Call me dumb but it seems I need to install the Emby add on manually, correct? If yes, must I install it (and configure it) before the installing the skin? Is there anything else I need to do manually before/after installing the skin to ensure smooth sailing?
EDIT: Installing EmbyCon first doesn't work (skin gave an error upon install). Installing skin first, then EmbyCon worked. Very nice skin so far.
morning ... im having a bit of difficulty... when using simple client pvr the pvr recordings hub show up.. when i click it, it opens a folder. is there any way to access that default folder thats created.. i cant find it anywhere... obviously i know there are no recordings in it im just experimenting with different ways to record.. been using tvheadend but trying something else..
thanks
I don't know if I get you right, but the content is based on what the PVR backend is returning. If you don't want folders you can go to the header bar and change the filter rules on the very rights. There is an option to flatten recordings.
(2019-11-13, 08:57)sualfred Wrote: I don't know if I get you right, but the content is based on what the PVR backend is returning. If you don't want folders you can go to the header bar and change the filter rules on the very rights. There is an option to flatten recordings.
when recording with tv headend the recordings folder is populated from the backed ... when using simple client it creates a recordings folder, as i can open the folder it means there must be a folder created somewhere.. but for the like of me i cant find it.. i have coded a recording path in simple client, and set it to the recording folder but pvr recordings still open to  a blank folder.
Not a skin issue. As far as I know the simple client isn't even support recordings so it doesn't seems to be official. I suggest you to head over to the PVR section.
  • 109
  • 110
  • 111(current)
  • 112
  • 113
  • 130
Embuary Skin20
