(2019-02-23, 15:15)SBOG Wrote: I still need to understand how the Custom Home section works, do you have some general info on this part?
When browsing your library/addon every item or path can be added as a skin favorite (Context Menu --> last item: Add to SKIN favorites). These favorite items can then be used to create your own home menu items and widgets. The best way to test this feature is to add a bunch of favorite items and paths, e.g.:
Select a TV show --> Context Menu --> Add to SKIN favorites
Select a Season --> Context Menu --> Add to SKIN favorites
Now go to custom home, select an empty spot and select your TV show favorite you created before. That's all, you should now have your first custom home menu item. Simply repeat this step if you want to add a widget to it.
There is also a template available for youtube (with more to come), so if you want to add support for youtube including widgets:
- Go to custom home --> Select empty spot --> Dialog --> Select Addons --> Select YouTube
That's it, you should now have a youtube home menu item with "My Subscriptions" and "Most Popular" widgets ...
I hope this helps a little bit, it's not that easy to explain every step
Quote:However, this seem to work only for "Movies" Library (from my Plex library), nothing is being displayed for the TV Shows. And for Movies, I only see the recently added, the In progress remains empty. (Not sure if this is a skin related issue)
Make sure that you have all dependencies installed: plugin.video.plexkodiconnect.movies and plugin.video.plexkodiconnect.tvshows. If that doesn't help I will take a look if there has been some addon changes ...
Quote:Contribution is done! Thank you for the great work
Thank you, I really appreciate your support!
