ontap
Posting Freak
2019-07-08, 00:01
(This post was last modified: 2019-07-08, 00:02 by ontap.)
Looks superb , am having bother trying to populate the dashboard . Using panel view , I left the default items in the dashboard panels, switched from screensaver to widget , but the dashboard panel on home page is still blank ,.
Have set up my library using PKC , but I see that doing this means you have more or less duplicate movie and tv show main menu items given that PKC populates the kodi library, am assuming the solution would be to disable kodi "movies and tv shows" from the main menu? given that I cant see how I would remove plex movies and shows ?
ontap
Posting Freak
Thanks , I see what you mean by PKC items other than movies and series, will have a mess around with dashboard feature and report back, also, have set u movies "root" and tv shows "root" as a couple of custom menu items , so I can access both sub menus from home page , but the custom menu items only show in list(vertical and horizontal) views , not in panel view ?
Thanks for the update. Question: I made homevideos as a custom home item. Is there a way to give that item a background?
Now the background is black, because there is no background. When I go in the menu item I can change everything, but not the main item itself?
Another question. Suppose you have only one movie "in progress". Then in the movie widget you can see that one movie, plus 7 empty templates.
Is there a way to remove that 7 templates so that you can only see that one movie. With 2 movies in progress 2 etc..
Maybe that's an option that I overlooked?
How can I set up a fallback image with the new update?
