v17 Log view on my kodi was loaded but every time I try to check the love I get a error
I need help with my kodi log view when I try to view the log I get a error message
A few questions (as obviously we can't ask for a log Smile )
Which OS are you using, and which version of Kodi?
What exactly are the error(s) that you are seeing?
Are you meaning the log viewer add-on from the repo, or the log uploader?
Which version of the add-on are you using?
|Banned add-ons (wiki)|Forum rules (wiki)|VPN policy (wiki)|First time user (wiki)|FAQs (wiki) Troubleshooting (wiki)|Add-ons (wiki)|Free content (wiki)|Debug Log (wiki)|
Kodi Blog Posts
I,m using Android box with Jarvis 17 when I try to view my log it says error plead view log . The error message is on both log viewer and log uploaded this is a add-on from the repo log viewer 2.0.0 from kodi
The log file is just a text file, which you can access via an android file manager of you have one available. It can be found in one on the following locations:
Note: The first folder might be different on various devices:
  • <data/sdcard/Android>/data/org.xbmc.kodi/cache/temp/kodi.log
  • /sdcard/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
  • /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp/kodi.log
If you can access it that way and then manually copy& paste it to PasteBin.com or somewhere similar we can have a look. Otherwise I think this one might be a bit tricky... 😉
Kodi Blog Posts
Log view on my kodi was loaded but every time I try to check the love I get a error0
