Is that Windows XP you are running?
Klojum
Lost connection
Windows XP supports upto XBMC Gotham, so that is unlikely to run Kodi 17.6.
How the hell did you even get it installed cause that shouldn't be allowed
I have latest windows, i have same problem
Yep, that is it.
Seems to be failing around the initialisation of the graphics portion of the log. You are using a AMD Radeon HD 7000 which is almost 6 years old. Should still work with Kodi, but you may need to update your drivers.
Let us know how that works.
eh is it 6 yrs old? my last tower died on me and this is pieced together PC I had lying around -_- but makes sense I'll see what I can do in the driver department thank you
