2018-05-22, 18:26
I got mine from ebay, but it's the 150 xt from minibox with this PSU http://www.mini-box.com/12v-12-5A-AC-DC-Power-Adapter
I've not tested it with my older 120
(2018-05-22, 18:26)luna_s Wrote: I got mine from ebay, but it's the 150 xt from minibox with this PSU http://www.mini-box.com/12v-12-5A-AC-DC-Power-AdapterThanks, i tested with another power brick and now works... mysteries.
(2018-05-19, 12:06)wait Wrote: PicoPSU-90 12V DC-DC ATX mini-ITX 0-90W Netzteil power supply, should work.Hi,
https://www.elefacts.de/test-67-asrock_j...or_im_test
(2018-05-29, 15:27)Orio Wrote: So, is the HD-Audio passthrough working for the model NUC7PJYH?
Is there a specific version of Libreelec/KODI I need to use to get it to work?
(2018-05-30, 19:50)DennisTA Wrote: If you would like to have also HDR the Nvidia Shield is the best choice IMO.I think the AMLogic S912 and Apple TV 4K are also worth considering (the latter runs MrMC - a fork of Kodi that is designed to be AppStore friendly) The AMLogic S905X (as used in Vero 4K and lots of no-name boxes) is also interesting - but there are question marks over whether it is a great fit for HDR as it appears to have to dither 10-bit to 8-bit at one point in its playback chain.
(2018-05-31, 11:44)noggin Wrote: If you want HDR out-of-the-box support in Kodi - Intel/AMD x86/x64 platforms are not a good fit. You have to run Windows (no current HDR Linux support) and even then you need to use external player solutions and run the right flavour of Core-i series chip (or have the right video card)Yes, it looks like that x64 and Windows is the only way if you don't want to compromise or sacrifice. The new "cheaper" AMD APUs like 2200GE and 200GE with Vega IGPs and native HDMI 2.0a-> 4K/HDR/VP9 (and possibly proper 3D MVC) support are also worth to mention. Oh, and don't forget this one: Cannon Lake NUC possibly coming with AMD IGP. -> Would be nice to see Intel going this way with their nextgen cheaper CPUs as well. But till they follow the "trend" which makes them cut the HDR on the Gemini, the chances are rather...
