Customize film lists
Hello,
is it possible to change/customize some things in the film lists? I would like to see some information from the film in the list and not in de description. In example, i would like to see in the list if the movie is sd, hd, 4k, hdr. Also the marker for watched films is a little bit confusing. It is possible to make a hook (like a checkbox). etc
many thanks in advance
You can use Smart Playlists (wiki) for that.
Not so much in the main/default video lists, but you can create separate lists.
Customize film lists0
