2018-02-15, 13:41
Sorry to start into the forum by a beginners question. Could not find a solution.
I have libreelec (devel-20180212221729-#0212-g760c839) running on a raspberry with tvheadend (4.2.5) on a separate server (ubuntu) with several dvb cards for pvr/livetv. Everything runs quite good.
There is only one problem. The process kodi.bin on the libreelec system keeps an active connection to my tvheadend server at port 9982 even if libreelec/kodi is idle/not in use. My tvheadend machine therefore is being kept from getting into suspend2ram mode. If I ignore the connection on my tvheadend system there are problems after remote wake, with epg updates, live tv and so on...
Is there a way to put kodi in "sleep mode" on the rpi (without turning it off)? Is there a recommended or best practice setup for the scenario?
