Thanks for the info. I have wanted to dabble with Flexraid but Unraid just seems to get better and better. Have you ever considered trying Unraid? I currently have been running Unraid for many years and I like it a lot. My sig has my build but since then I have updated the PSU and CPU, along with all hard drives. Currently at 104TB of storage with 2 parity drives. My parity check monthly takes about 18 hours. Upgraded the cpu so I could run a Plex server and stream more clients on the server. Psu was upgraded because of the higher power for the 7200 rpm drives. I idle at about 100watts and have the server connected to a battery backup in case or power failure.
It is fun to have storage for whatever needs you want.
A word of warning, do not use SATA cards especially not $35 ones
The reason being is that I done the same years ago now, I brought for example 8 3tb drives, I had four on my mobo sata ports, and then I had four on my sata card.
In the space of a year all of the four that were on the SATA card failed and the four that were on the mobo sata ports have lasted till this day.
They were all the same drives, a sata board especially a cheap one, is not safe.
You can either listen to my advice or end up crying because you are going to lose a lot of hard drives and also what is on those hard drives.
I now buy second hand mobo's with as many ports as I can find, and use them, it is better to have multiple PC's than putting all your eggs in one basket and seeing the lot go down.
(2019-11-09, 16:04)DJ_Izumi Wrote: (2019-11-09, 12:55)Video Titles Wrote: A word of warning, do not use SATA cards especially not $35 ones
Look at my last post in this thread where I make an update. It's the only post in this thread for over a year. It's the post that bumped this thread.
Quote:I also traded out the Syba SATA controller mess for a single 16 port LSI SAS controller
Now look at the most recent case photo, the one where you can clearly see an LSI SAS 9201-16i in a single slot where 4x Syba controllers once sat?
Cool, thanks, good reading.
Also, no, a SATA controller can't KILL drives.
lol so it was a fluke that all of the drives that I had on a sata card all died around a year, and yet the ones on the mobo are still working four or more years later? As I say, I have warned you, if you have upgraded since then to a better more expensive card which can be more stable, but I can only speak from experience, cheap sata cards can KILL drives.
Hi DJ,
I have a quick question for you about Flexraid.
I have followed a fairly similar path to you with my Flexraid server starting with 3x 3tb drives to now having a mix of 9 drives that total 38TB with a 14tb parity drive and a system SSD. I have them all in an old tower case with an ancient q6600 CPU.
I want to upgrade the CPU, motherboard and memory but as you know Flexraid is not supposed to be transferable between systems. I was wondering how you managed the upgrade from 2500 to Xeon chip?
Thanks very much
Thanks for the reply. I know deep down that you're right and I should upgrade the software first before the hardware but Flexraid is just so, well, flexible for my purpose.
Maybe I'll prepare myself for a potential drivepool/snapraid migration in case Flexraid fails to relicense after the hardware change.
2021-01-25, 16:26
(This post was last modified: 2021-01-25, 16:27 by jmgibson1981.)
I use Linux rather than Windows. In my case I use mergerfs which I think is along the same line as DrivePool. I've had great success combining that with Snapraid. Snapraid is easy to use, just did my first disk replacement the other day. Took awhile as my parity drives are USB so limited i/o. But it worked out just fine. I highly recommend snapraid any time. As I understand it it's being put into the next Debian release so it will be around a long time, and open source as well so you can depend on it being around without worrying about licensing.
