I am looking everywhere to find Kodi 18 64bit for windows 10 and/or Kodi 17.6 64bit.
The website indicate that you can download 17.6 and it will ask if you prefer 64bit, but it does not.
Anyone has seen Kodi 17.6 or 18 with 64bit?
Sincerely and thank you,
Claude
Hello ClaudeIsGettingIN17
Kodi 17.6 64 bit does not exist. Only 32 bit is available. Please point me to the website that states otherwise.
Kodi 18 has a 64 bit version available. It is still a Development Build, but can be downloaded from the "Download" link at the top of the page.
Hi Karellen,
Is Kodi v18 with 64bit available and if yes where someone can download?
Claude
Yes it is available. It is a Development Build, this means it is still being designed, but is available for testing purposes. If you want a hassle free experience, then download v17.6 that is compatible with all skins and add-ons... v18 is not. Don't be fooled by the hype of 32bit -v- 64bit. I still use the 32bit version.
As mentioned in my previous post, use the Download button at the top of the page.
Thank you for all the information and will take your advice and do the 17.6.
hi if it helps you out i have Kodi 64bit master.
