  • 7
  • 8
  • 9(current)
  • 10
  • 11
  • 147
v18 Aeon MQ 7 Leia Mod
@kow1234
I don't use trakt, but I'll take a look.
Kodi v17.6 "Krypton" (Aeon MQ 7 Krypton Mod v2.0.0.9) running on Windows 10
Kodi v18.8 "Leia" (Aeon MQ 7 Leia Mod v1.0.2.5) running on Windows 10/Amazon Fire TV
Kodi v18.8 "Leia" (Aeon MQ 8 Multi-Mod v2.9.0) running on Windows 10/Amazon Fire TV Cube
Youtube Channel
i got it working i just had to wait when switching from one widget to another there is a bit of a delay but works now. is there any chance that an option to detach widgets from menu be added and maybe a program node. it seems that u cant put a program addom as a widget
Anyone else getting a "skin helper service" error at startup? Could use suggestions on a fix.
yes i get also the same error
@melons2
@rico12345
I'm using the latest skin helper service v1.1.24. Give that a try and see what happens.
Also, I fixed the player controls for the horizontal menu...they were only displaying if you had the vertical menu enabled.  It will be part of the next update.
Youtube Channel
@movie78
I fixed the subtitle problem...subtitles have their own OSD button with Leia. It will be part of the next update.
Youtube Channel
(2018-04-11, 19:57)latts9923 Wrote: @movie78
 Perfect, Thanks!
MY CURRENT MEDIA PLAYER | MY HOME THEATER
MINIX NEO U9-H LIBREELEC v18 Leia | EGREAT A10 | NVIDIA SHIELD | SAMSUNG QLED QN75Q7 | Sony 43 Android TV HDR
XBOX ONE X UHD BLU-RAY | PS4 PRO 4K w/PSVR | NAKAMICHI PRO 7.1.4 DTS:X/ATMOS
I also have the skin helper service error using v1.1.24 (xbox one), but according to one of the forum posts the problem is with the cherrypy module.
Here's the link to the post: post #3921
https://forum.kodi.tv/showthread.php?tid...6&page=262
@latts9923
Testing between EstuaryMOD it seam like the take a little long to display poster and fanart, is there a way to speed the loading?
PS:Tested on LibreElec NUC and Android device same results.
@movie78
I looked at the code on the EstuaryMOD skin...I can't see much of a difference right now, but I'll keep looking.
Youtube Channel
UPDATE #4
ImageMain menu player controls
The player controls were not displaying if the horizontal main menu was enabled.  Thanks to melons2 for reporting the bug.
ImageOSD subtitle button
The OSD subtitle options were not working.  The subtitle button in the OSD menu now opens the subtitle control window.  Thanks to movie78 for reporting the bug.
ImageSkin Settings background image
I updated the skin settings background image.
04-12-18 Update (This will update the skin to v1.0.0.5)
Youtube Channel
Problem updating from v1.0.0.4 to v1.0.0.5
Can't install on xbox one im getting permission errors while transfering the files manually, and wont install using the install from zip keep getting missing files error after installing then trying to switch skins.
Edit:
Nevermind, fixed the install by using the full install on the main page.
(2018-04-09, 14:46)movie78 Wrote:
(2018-04-09, 11:32)SteveSmith Wrote: Tried to install 1.0.0.3 onto the Xbox One X Version of Kodi and it failed saying script.games.rom.collection.browser could not be satisfied?
Any Idea how to fix this? I tried to install script.games.rom.collection.browser manually but it also too failed.
 Install Estuary MOD V2-KODI 18
In the Estuary MOD there a section where it allows you install all the missing Addon, once that it complete try installing Aeon MQ7 Leia Mod again.
 Still getting a dependency Issue, with this script.games.rom.collection.browser, Just tried again with 1.0.0.5 and just refuses to install on the Xbox One X.
I installed the Estuary Mod as suggested, and this script doesn't show up as needed in the script.
I also tried on Win10, and grabbed an error log after it also failed to install.
10:42:55.543 T:13656   DEBUG: Unpacking zip://E%3a%5cskin.aeonmq7.leia.mod-1.0.0.5.zip/skin.aeonmq7.leia.mod/ to C:\Users\Slider\AppData\Roaming\Kodi\addons\temp\820aaf02-5663-428a-8fe8-c5ac21fadb0f
10:42:58.178 T:13656   ERROR: XFILE::CFile::Rename - Error renaming file C:\Users\Slider\AppData\Roaming\Kodi\addons\temp\820aaf02-5663-428a-8fe8-c5ac21fadb0f
10:42:58.178 T:13656   ERROR: Failed to move new addon files from 'C:\Users\Slider\AppData\Roaming\Kodi\addons\temp\820aaf02-5663-428a-8fe8-c5ac21fadb0f' to 'C:\Users\Slider\AppData\Roaming\Kodi\addons\skin.aeonmq7.leia.mod'
(2018-04-13, 02:22)latts9923 Wrote: UPDATE #4ImageMain menu player controls
Download04-12-18 Update(This will update the skin to v1.0.0.5)
 Thanks for the new update...
@Min2001
Good deal...glad you got it working.
Youtube Channel
  • 7
  • 8
  • 9(current)
  • 10
  • 11
  • 147
Aeon MQ 7 Leia Mod13
