2018-04-23, 19:01
(This post was last modified: 2018-04-23, 19:02 by melons2.)
Hey Latts,
I like the pulsing "Pause" in the movie screen but I am wondering if you would tell me which file that is in so I can change it to add the "Time left" in hours and minutes above the blinking 'Pause" you currently have?
2018-04-26, 16:37
(This post was last modified: 2018-04-26, 16:39 by jasn.)
Greetings. For Music I'm having trouble enabling JB's animated lyrics and am not seeing the logos cycle as they did in Krypton. Am I missing a setting somewhere or two? I've been scouring the menus everywhere.
I'm using Windows 10, BTW, and assume I no longer have to modify the MusicVisualization.xml file as originally needed in Krypton?
Thx
2018-04-28, 03:59
(This post was last modified: 2018-04-28, 04:12 by melons2.)
Thank you............for your help.
2018-04-29, 19:11
(This post was last modified: 2018-04-29, 20:57 by melons2.)
Thanks..........I reinstalled it and then changed some of it's settings.......and it works.
it will only work for a 7 day view, days of week on the side with smaller thumbs now.
It used to be able to show 15 day scrolling view, days of week at top and larger thumbnails.........
But it works!
@"chrissix"
The Leia Mod contains everything from the Multi-Mod for MQ 7 Krypton. Every update I post for the Multi-Mod gets applied to this Mod as well.
Concerning the addons...
Artwork Downloader - This addon is no longer supported in Leia. I've been using Artwork Beef and it seems to be working fine.
MovieSet Artwork Automator - I haven't tried this addon yet with Leia.
TVTunes - This addon can not be discussed on the forum any longer.
TVShow Next Aired - I'm looking into this one as we speak.
ExtendedInfo Script - I haven't tried this addon yet with Leia.
Steam - Is this the Steam Launcher addon? I don't use Steam for anything...perhaps someone else can chime in on this one.
Youtube - I believe this addon is in the Leia KODI Repo.
Videoextras - The thread for this addon has been closed since 2015. I'm pretty sure it will need updated to work with Leia. It may also be an addon we can't discuss any longer.
Global Search - I believe this addon is in the Leia KODI Repo.
