latts,
Great work. I installed the 1.0.8 version and everything is working fine except the ratings for movies. All IMDB, Critics, Ratings, etc are coming empty. I installed the mod on Kodi Leia running on Fire TV (pendant). Am I missing something?
I just noticed that I forgot to include the new code for the Video Info screen to the Leia Mod...it's only in the Krypton Multi-Mod. Doh!
I'll include that in the next update. Sorry folks!
2018-10-17, 04:01
(This post was last modified: 2018-10-17, 04:02 by embeleco.)
Latts,
Yes I added the API for the fanart.tv but still nothing is showing up when checking the information of a movie for example.
I checked the Metadata and Artwork Module plugin on an existing Krypton instance that I have with the original AEON MQ7 and when configuring the plugin I can see the API Keys option for the fanart, OMDB, etc. But when accessing that same plugin on Leia with the Mod I can only see one API Key for FanArt available and under an "Other" section.
Is that normal?
I can't get the trailers working with version 1.0.0.7 or 1.0.0.8.
When in movie info, I press the "Trailer" button, nothing happens.
Trailers are playing without problem with the default Estuary skin.
Can you help me ?
Thanks,
Eric
