  • 33
  • 34
  • 35(current)
  • 36
  • 37
  • 139
v18 Aeon MQ 7 Leia Mod
@latts9923 Yes I do have resource.images.mediaicons.coloured addon installed however could not find the any subfolder there
@crazy-c
Try uninstalling and reinstall that addon. There should be a resources subfolder that contains a Textures.xbt file.
Kodi v17.6 "Krypton" (Aeon MQ 7 Krypton Mod v2.0.0.7) running on Windows 10
Kodi v18.6 "Leia" (Aeon MQ 7 Leia Mod v1.0.2.3) running on Windows 10/Amazon Fire TV
Kodi v18.6 "Leia" (Aeon MQ 8 Multi-Mod v2.9.0) running on Windows 10/Amazon Fire TV Cube
Youtube Channel
@latts9923 Image
Why can't the score be displayed? Is there no CD on the [email protected]latts9923
And I reinstalled 14.0.10+Multi-Mod addition and the results are still the same.
(2018-12-14, 16:09)qizhouzhangsheng Wrote: Why can't the score be displayed?
Did you create an API key?
https://www.omdbapi.com/apikey.aspx
(2018-12-14, 16:09)qizhouzhangsheng Wrote: @latts9923 Image
Maybe because you use an addon with not so legal streams?
Can you please tell me where you put the api key? cheers
9.1 Cinema Room htpc with Kodi Matrix & emby server~Epson EH-TW9300~Homemade 8ft pj screen~AVR~Yamaha RX-A3070~Speakers~Monitor Audio RX6 Fronts & RX Centre~RXFX Surrounds~250's Rears~180's Front Presence~BK XXLS400 Sub~8033C AntiMode~HarmonyOne
Settings - System - Addons - Manage Dependencies - Metadata and Artwork Module -API Keys.
(2018-12-15, 21:55)MB1968 Wrote: Settings - System - Addons - Manage Dependencies - Metadata and Artwork Module -API Keys.
 Cheers for the reply MB1968 , found where to put it in my case it was Settings - System - Addons - Metadata and Artwork Module - API Keys, but still hasn't helped me get the scores, ratings or votes to show , cheers
After you have entered your key you need to delete the simplecache.db file so it picks up the new ratings. Go to file manager. Navigate to .kodi/userdata/addon_data/script.module.simplecache  --> Delete simplecache.db
Note: If you dont see the .kodi folder you may need to enable the hidden files and directories option in kodi settings.
Cheers Maukoo that sorted it, but even though I had hidden files enabled I still couldn't see the simplecache.db file in kodi files manger so just deleted it in the installation dir. Thanks
Isn't the free Omdb invalid?
(2018-12-16, 13:35)wints Wrote:  Cheers for the reply MB1968 , found where to put it in my case it was Settings - System - Addons - Metadata and Artwork Module - API Keys, but still hasn't helped me get the scores, ratings or votes to show , cheers
Yes. That's another way of doing it.
(2018-12-16, 18:40)qizhouzhangsheng Wrote: Isn't the free Omdb invalid?
It's not invalid. But it only allows 1000 api requests per day. In most circumstances this will be enough. Regarding the extended artwork: the skin is designed to display extended artwork for your video, tv show and music library. Not for addons. It depends on the addon what types of artwork will be displayed. Contact the addon developer if you would like to see more options for artwork.
UPDATE #11
ImageAdditions
  • There is a new radio button in the music player settings to enable/disable Video Lyrics by Manfeed. Thanks to emiralles for providing the addition.
  • There is a new version of JB Similar Artist for styles 5, 7 and 3D. There are two new files associated with this...JB_Includes_v2.xml and JB_PodobniArtysci_v3.xml. I've had version 3 available for a while, but never changed the code to use it. Thanks to emiralles for prompting the update.
ImageBug fixes
  • I adjusted the size of the fanart shadow for KodiFlixTV. I forgot about that shadow on the last update. Thanks to nomnom27 for reporting the bug.
  • I adjusted the position of the Rotten Tomatoes percentage label for KodiFlix. At 100% it was overlapping the image. Thanks to MB1968 for reporting the bug.
ImageMaintenance
  • I did a little housecleaning to some of the files.
12-17-18 update (This will update the skin to v1.0.1.2)
Youtube Channel
  • 33
  • 34
  • 35(current)
  • 36
  • 37
  • 139
  • 13 Vote(s) - 4.54 Average
Aeon MQ 7 Leia Mod4.5413
