  • 39
  • 40
  • 41(current)
  • 42
  • 43
  • 143
v18 Aeon MQ 7 Leia Mod
@Wanilton
Thanks for the heads up! It's strange that only the albums are not working. Do the widgets depend on script.skin.helper.widgets? I'm using v1.0.38...same on your side?
Kodi v17.6 "Krypton" (Aeon MQ 7 Krypton Mod v2.0.0.8) running on Windows 10
Kodi v18.6 "Leia" (Aeon MQ 7 Leia Mod v1.0.2.4) running on Windows 10/Amazon Fire TV
Kodi v18.6 "Leia" (Aeon MQ 8 Multi-Mod v2.9.0) running on Windows 10/Amazon Fire TV Cube
Youtube Channel
I'm on my regular work now, but yes, its the same version. I don't have time enough for check the skin code used in your mod.
MediaBrazil forum Website - Youtube Channel
Aeon MQ9-0.4.0 & Ace2 Skin Team
MarcosQui Website Donate and support us.
@Wanilton
No worries bud. Thanks for your help!
Youtube Channel
1. Hi i want to start the mainmenue with movies, but kodi starts always with TV-Shows.
How can I change this?
2. Is it possible to update the skin automatically?
3. Is artworkbeef preinstalled?
@klarahimmel
1. There is a bug with Leia where TV Shows is displayed by default only with the horizontal main menu...I'm still unable to fix the bug. The vertical menu does not have that problem.
2. I'm working on making updates to the skin available on my Repo. It's not entirely stable yet...still working on it.
3. Artwork Beef is a separate install.
Youtube Channel
Just updated to Kodi Leia RC5 and now my Aeon MQ7 leia mod has disappear
Any help!
MY CURRENT MEDIA PLAYER | MY HOME THEATER
MINIX NEO U9-H LIBREELEC v18 Leia | EGREAT A10 | NVIDIA SHIELD | SAMSUNG QLED QN75Q7 | Sony 43 Android TV HDR
XBOX ONE X UHD BLU-RAY | PS4 PRO 4K w/PSVR | NAKAMICHI PRO 7.1.4 DTS:X/ATMOS
@movie78
Check this post
https://forum.kodi.tv/showthread.php?tid...pid2804876
(2019-01-03, 14:43)Wanilton Wrote: XBMC GUI = 5.14.0 in Kodi Leia 18 RC5, mod author need fix the addon.xml file for fix. Or change yourself 5.13.0 to 5.14.0, will solve.
@latts9923, the widget for music recently albums work fine here with mq8 using the same script skin helper service version, i don't have issue in my MQ7 mod version too.
 @Wanilton
I change 5.13.0 to 5.14.0 in the addon.xml file and still doesn't work.
import addon="xbmc.gui" version="5.14.0"/>
Any help
I have the same problem. Changed the xml file to what was suggested and the skin stil does not appear in my list.
Fyi I am running on Kodi 18!on the Nvidia shield TV. Latest updates etc.
Hi there,
I recently downloaded the 1.0.1.3 version and it have a size of 244 MB. Yea, Mega Byte.
Could this be correct?
Greetings
(2019-01-05, 13:48)K1ngLear Wrote: Hi there,
Greetings
Yeah that's the correct size for the full skin
9.1 Cinema Room htpc with Kodi Matrix & emby server~Epson EH-TW9300~Homemade 8ft pj screen~AVR~Yamaha RX-A3070~Speakers~Monitor Audio RX6 Fronts & RX Centre~RXFX Surrounds~250's Rears~180's Front Presence~BK XXLS400 Sub~8033C AntiMode~HarmonyOne
@movie78
@ttringle
I just installed the latest nightly and the skin is working.
Youtube Channel
(2019-01-05, 07:01)ttringle Wrote: I have the same problem. Changed the xml file to what was suggested and the skin stil does not appear in my list.
 I am on Nvidia Sheild too and @latts9923 its still not working:
@movie78
Hmm...I installed the Windows version. Let me install the latest Android nightly on my FireTV Cube and see what happens.
Youtube Channel
(2019-01-05, 15:15)latts9923 Wrote: @movie78
  • 39
  • 40
  • 41(current)
  • 42
  • 43
  • 143
Aeon MQ 7 Leia Mod13
