  • 46
  • 47
  • 48(current)
  • 49
  • 50
  • 144
v18 Aeon MQ 7 Leia Mod
@vansai
@stellzz
Here is how to add the reboot to android button in shutdown menu
1. If you don't know how to edit files on your box, download program Winscp on PC and login into your box.
2. Navigate to aeon mq 7 folder .kodi/addons/aeonmq7.leia.mod/1080i/
3. Double click the DialogButtonMenu.xml to open file.
4. Search for the word reboot you should see code similiar to following
<item>
<label>Reboot</label>
<onclick>XBMC.Reboot()</onclick>
</item>
5. Under that paste the following to add the button.
<item>
<label>Reboot to Internal</label>
<onclick>System.ExecWait("/usr/sbin/rebootfromnand")</onclick>
</item>
Save changes and reboot box or reload skin. Press letter S on keyboard to bring up the shutdown menu.
Reboot to internal should be there. It may take a few seconds to restart. Tested using libreelec.
Hope this helps Smile
@jasn
You're welcome!
Kodi v17.6 "Krypton" (Aeon MQ 7 Krypton Mod v2.0.0.8) running on Windows 10
Kodi v18.6 "Leia" (Aeon MQ 7 Leia Mod v1.0.2.4) running on Windows 10/Amazon Fire TV
Kodi v18.6 "Leia" (Aeon MQ 8 Multi-Mod v2.9.0) running on Windows 10/Amazon Fire TV Cube
Youtube Channel
@the_bo
I was going to try that command, but I haven't been able to load LibreELEC on a device with an internet connection. I have it running on a USB drive, but when it boots the network connection list is empty. If that command works I'll go ahead and add it to the skin. Thanks!
Youtube Channel
(2019-01-21, 19:46)melons2 Wrote: In order to take full advantage of this mod which scrapers should I be using?
1. Movies/video:  Universal scraper, The Movie Database or local information only?
 I used to scrape with local infos, but that didn't work with ratings.
Now i'm using the universal scraper and all infos show up.
i believe they are only stored in the database, because none of the ratings show up in an exported kodi-infofile.
Odroid-N2 CoreElec Kodi 18.5 with Aeon MQ 8 Leia Mod
RP3b+ LibreELEC Kodi 18.5 with Titan MOD
Synology DS 218+ (nfs) 14 TB
@the_bo or anyone else that can test this...
I added an option for the Shutdown submenu but I can't test it since my LibreELEC is not on the network. Open IncludesMenuCustom.xml and find...
<item>
<label>31059</label>
<!-- Reiniciar sistema -->
<!-- 6012 -->
<!-- 6015 -->
<label2>31059</label2>
<property name="id">shutdown</property>
<onclick>Skin.SetString($INFO[Skin.String(custom_master)],reboot)</onclick>
<onclick>Skin.SetString($INFO[Skin.String(custom_action)],Reboot)</onclick>
<include>DefaultReset</include>
</item>
Under that add...
<item>
<label2>Reboot to Internal</label2>
</item>
If you reload the skin and add a submenu item to Shutdown you should see "Reboot to Internal" as one of the options near the bottom of the list. See if that one works if you would. Thanks!
Youtube Channel
Hi @latts9923
Unfortunately i can't test either as have overwritten libreelec system but code looks good.
Keep up great work Smile
What does the option: "show zoom window in home screen (Audio/Video)" do?
Tried it but I see no change?
Hello! I need some help, please!
I could't find out it is how to make the extrafanarts roll in the background in the movies and tv shows windows. i I'm using artwork beef with out any problems in other skins, but i cannot find out what is the problem.
In the movie folder there is a extrafanart folder with the extrafanarts.
I selected the option to show extrafanarts.
But i can only see the fist picture on the background.
Any ideas?
delete
XBoxMediaCenter (Kodi Leia) 18.0 , LibreElec RasPi3 Libreelec-Leia Skin AeonMQ6
(2019-01-24, 00:11)Angelinas Wrote:
(2019-01-23, 20:13)melons2 Wrote: What does the option: "show zoom window in home screen (Audio/Video)" do?
IncludesMainMenu.xml
all code
Skin.HasSetting(8)
change in to
System.IdleTime(8)
 Thank you!
@Angelinas
I have never even tried that setting. Thanks for the tip! I'll make that change in the Krypton Mod as well.
Youtube Channel
Hi @latts9923
Please see below pictures:
As you can see, I've got most things working, except there's some information missing in the info screen. Also, the awards doesn't show up for me at all.
Am I missing an add-on or is the information missing from my .nfo file?
Kodi v18.7 (AEON MQ 7 Leia Mod) running on Windows 10
@JanM201
I would close KODI, remove simplecache.db, open KODI again and allow everything to repopulate. That should fix your missing data.
Youtube Channel
(2019-01-24, 15:43)latts9923 Wrote: @JanM201
 Not working for me
Also i tested a different scraper
To take full advantage of this skin (critics and ratings) you need the UniversalMovieScraper, but i have to use TMDB-scraper because UMS has a bug with scraping in a non english language.
I'm also using IMDB-Ratingsupdater (Light) and the Movietagger-addon, but no Oscars show up.
Seems @JanM201 and i have a similar installation.
but to be fair, the skin (and mod) is awesome and the info-screen is a "nice-to-have" but not a "need-to-have"
@JanM201
@Gothico
and everyone else...
I was looking at the update files from when I added the awards code and noticed that I never provided the awards images to go along with it...oops! I added them to the Krypton Mod, but not the Leia Mod. Below is a download containing the images you need...sorry! You should already have a resources folder under media...just copy these images into that folder and you should be good to go.
Awards images
Youtube Channel
  • 46
  • 47
  • 48(current)
  • 49
  • 50
  • 144
Aeon MQ 7 Leia Mod13
