2019-01-30, 20:52
(2019-01-30, 15:51)latts9923 Wrote: @pittsoccer33Thanks a lot of looking. I'm on a Shield with the official Play store version of 18. I might try nuking it and starting from scratch.
I am unable to reproduce the "0" Top250 problem you've reported. I'm with @Gothico...might be your version of Leia. What version are you running?
Just so I know what to look for - should the IMDB rating be down with the media flags (where both #0 and actual top 250 rankings are showing), up above near the synopsis (where only actual top 250 rankings are appearing), or both?
(2019-01-30, 15:51)latts9923 Wrote: I'll have to check again, but I believe you can customize the case color and which flag is displayed for that case in Skin Settings.
I saw the color option, but I could i add my own logo/flag for HD-DVD?
