2019-02-11, 06:59
Found fix for anyone else experiencing same problem:
https://forum.silicondust.com/forum/view...73614fc1c3
(2019-02-11, 02:29)19Ted54 Wrote: Hello and some help, please!
I have on a Win10 PC updated from 'Krypton' with an Aeon MQ 7 mod to 'Leia'. The skin was disabled during the update and I installed the latest Aeon MQ 7 Leia mod V 1.0.1.4. Then I took the old skin 'settings.xml' and put it in the new skin folder. Restart and everything was there and O.K. apart from:
# 1 - The horizontal menu bar (orange bar under 'settings on photo 2 in post #1 in this thread) is missing and I cannot find a way to activate it on the settings.
# 2 - The standard first item when starting in the home window was 'Movies' - now it is 'TV Shows' and I cannot find a way to change that.
Thank you for your help!
Best, Eduard
(2019-02-11, 13:22)koldtoft Wrote: Is it possible to change this color? #1c1c08 which I think is the "default" skin color.Not sure if it will work, but you can check under Skin settings at the bottom of the list, then in Colours.
I think it's the "default colour" but in the skin settings it's locked
The color I am trying to change is the "background panel" color for movie and tv info panels. Both when it's solid and semi transparrent
(2019-02-11, 13:52)SteveSmith Wrote: Not sure if it will work, but you can check under Skin settings at the bottom of the list, then in Colours.
I see a Change panel colour and a Titles colour section.. Not tried it myself
(2019-02-11, 13:52)SteveSmith Wrote: The color I am trying to change is the "background panel" color for movie and tv info panels. Both when it's solid and semi transparrent
<control type="image">
<left>0</left>
<top>0</top>
<width>1920</width>
<height>45</height>
<texture>darkgrey.png</texture>
<colordiffuse>$INFO[Skin.String(colortexture)]</colordiffuse>
<include>Animation_DefaultGlass2</include>
</control>
<setting id="mymenubar" type="string">mq7menubar</setting>
<setting id="myverticalmenubar" type="string">mq7menubarvertical</setting>
(2019-02-11, 20:04)chrissix Wrote: I hope I could give you a little food for thought, Leave a thumb up if it helped. Greetings, Chris
(2019-02-11, 02:29)19Ted54 Wrote: Then I took the old skin 'settings.xml' and put it in the new skin folder. Restart and everything was there and O.K. apart from:Have I understood that correctly? You simply copied the old settings.xml from krypton to leia?
