LibreELEC has very recently released it's stable Leia 9.0.0 RELEASE.
I have a query before I upgrade... will my Aeon MQ7 Krypton Mod settings that I have backed up using 'Skin Helper Service Skin Backup' be compatible with the Aeon MQ7 Leia Mod v1.0.1.5?
Or will I have to use the Kyrpton 'settings.xml' file in '.kodi/userdata/addon_data/aeon.mq7.mod/settings.xml' folder?
Thanks in advance!
Don't know how many people using kodi local trailer feature.
I guess there are some cause many using this skin with a Media Manager and there is great trailer support for that.
This is a little mod where the Trailer Preview Thumb will be shown when the trailer button is on focus.
There is a little delay so it does not pop up right away if you just switch through the menu bar.
Also only visible on Detail Mode (extended ratings view)
@"chrissix"
You're welcome! And thank you for contributing your code to the effort!
I will continue to update the Krypton Multi-Mod alongside the Leia Mod. Most of the code is just a copy and paste from one to the other, so it's pretty easy to maintain both at this point.
You bet there's plans for an MQ 8 mod! I'll get started on it as soon as it's released!
I just tried a test upgrade to v1.0.1.6 of the Leia Mod via my Repo...and SUCCESS! I also tried installing after a fresh install of Leia and it worked like a champ. I will test this out a few more times to verify.
Please don't use the Repo yet as an install or update method. I'll let you know when it's ready to try out.
Never-mind about the showing the current time on the main menu. I see that it comes with the date. It looks fine!
Maybe the time used to show on the sub-menus?
