Hi Jeff, Great skin. I have a few things I noticed about the skin, that I might have setup wrong.
1. When looking at a season and episode I just watched, when finished it does not get marked as watched unless I manually set it thru the context menu. I am in right list mode.
2. I have the TV Shows - in Progress widget selected in my shows catagory. I select the show to watch from the widget, works fine. when I am finished watching the watched flag never gets set, when I use the context menu to select watched, the widget doesn't seem to update correctly and the program stays in the list of in progress shows, it seems to only disappear with a restart of kodi. I did notice, that if I mark the widget as watched, it does update the watched flag in my right list view as mentioned in item #1
Any help that you could offer is very much appreciated.
Again, Great skin, I look forward to continue using it for a long time.
the_bo
Posting Freak
I haven't tested latts new mod yet but can anyone tell me when the AB: extrafanart option is enabled does it include the original fanart.jpg in the slideshow or only the fanart1.jpg, fanart2.jpg etc.
I always pick the best image for the main fanart.jpg so would like this to show with extrafanarts
Or does enabling extrafanart only show the extrafanart without the main fanart.jpg image?
Thanks for any info
wags1
Posting Freak
I have a question about music layout 7. I really like it but for some reason it will not show the graphics on the spinning disk. It doesn’t seem to matter if I set show logo on disk on or off (honestly that setting doesn’t seem to do anything in layout 6 either). If I switch back to layout 6 I get the graphics on the spinning disk.
