  • 101
  • 102
  • 103(current)
  • 104
  • 105
  • 140
v18 Aeon MQ 7 Leia Mod
(2019-05-06, 20:02)shedrock Wrote: I am a bit confused with how the extrafanart works. For example I have a TV series called "Splitting up Together", but unless I create an extrafanart folder, the fanart isn't being displayed at all. I have to turn on Default Fanart, which obviously defeats the purpose. I also noticed that I have Artwork Beef set to download the extrafanarts into a folder, but that doesn't work either, but if I turn off that option, it then copies it to the root, which I figure might be an AB issue, but as to the skin itself I am confused why it doesn't work as it should.
I just checked your previous version 1.0.1.6 and it works correctly. By that I mean, if the TV show only has the default fanart.jpg, then that's what is displayed, and if extrafanart exists it displays that also. Whereas, in 1.0.1.7 it doesn't display the fanart.jpg if there are not extrafanarts available.
UPDATE:
This apparently is needed for the fanart.jpg to work if the TV series does not have extrafanart. I re-added the following and it seemed to have resolved the above issue:
        <!-- MULTI MOD -->
        <include>AB_Fanart</include>
        <control type="fadelabel" id="4420">
            <top>-1000</top>
            <width>2560</width>
            <height>0</height>
            <scrollspeed>20</scrollspeed>
            <scrollout>false</scrollout>
            <font>Font-LineLabel</font>
            <textcolor>white</textcolor>
            <randomize>true</randomize>
            <pauseatend>5000</pauseatend>
            <resetonlabelchange>true</resetonlabelchange>
            <label>$INFO[ListItem.Art(fanart)]</label>
            <label>$INFO[ListItem.Art(fanart1)]</label>
            <label>$INFO[ListItem.Art(fanart2)]</label>
            <label>$INFO[ListItem.Art(fanart3)]</label>
            <label>$INFO[ListItem.Art(fanart4)]</label>
            <label>$INFO[ListItem.Art(fanart5)]</label>
            <label>$INFO[ListItem.Art(fanart6)]</label>
            <label>$INFO[ListItem.Art(fanart7)]</label>
            <label>$INFO[ListItem.Art(fanart8)]</label>
            <label>$INFO[ListItem.Art(fanart9)]</label>
            <label>$INFO[ListItem.Art(fanart10)]</label>
            <label>$INFO[ListItem.Art(fanart11)]</label>
            <label>$INFO[ListItem.Art(fanart12)]</label>
            <label>$INFO[ListItem.Art(fanart13)]</label>
            <label>$INFO[ListItem.Art(fanart14)]</label>
            <label>$INFO[ListItem.Art(fanart15)]</label>
            <label>$INFO[ListItem.Art(fanart16)]</label>
            <label>$INFO[ListItem.Art(fanart17)]</label>
            <label>$INFO[ListItem.Art(fanart18)]</label>
            <label>$INFO[ListItem.Art(fanart19)]</label>
            <label>$INFO[ListItem.Art(fanart20)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart1)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart2)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart3)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart4)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart5)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart6)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart7)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart8)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart9)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart10)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart11)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart12)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart13)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart14)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart15)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart16)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart17)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart18)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart19)]</label>
            <label>$INFO[ListItem.Art(tvshow.fanart20)]</label>
        </control>
Thanks,
Shedrock
Sorry to ask, but ....which file do I add your code to?
Thank you
@melons2 - Sorry, it can be found in MyVideoNav.xml.
Shedrock
Galatians 6:7 (KJV) - Be not deceived; God is not mocked: for whatsoever a man soweth, that shall he also reap.
How to turn on animated lyrics, there is no option.
Is it possible to get widget for YouTube, Steam and Twitch?
I found for lyrics. Is there way to switch to Shelf3D view faster?
@latts9923 Thanks for the update and great work!
Is there any way to add 'Restart' to the 'Smart sub-menu'?
Hello Super Noob here, I'm have trouble bringing up any of the 3d views in music, if been looking through the site for days and cant figure it out, someone please help me.
(2019-05-13, 00:02)dchurch595 Wrote: Hello Super Noob here, I'm have trouble bringing up any of the 3d views in music, if been looking through the site for days and cant figure it out, someone please help me.
Go to music and hit arrow left and arrow up two times and click to activate Shelf 3d. To change view, in music,choose albums hit arrow left and arrow up and select view.
Thanks but I've done that, I clicked all the toggles to green but when I scroll through the views to preview nothing.
@dchurch595
You must be in music than click on albums and change view.
(2019-05-12, 23:03)mataus19 Wrote: @latts9923 Thanks for the update and great work!
Anybody know if this is possible?
@mataus19
You're welcome...and thank you!
Is "Restart" not one of the options in the Shutdown sub-menu?
Kodi v17.6 "Krypton" (Aeon MQ 7 Krypton Mod v2.0.0.8) running on Windows 10
Kodi v18.6 "Leia" (Aeon MQ 7 Leia Mod v1.0.2.4) running on Windows 10/Amazon Fire TV
Kodi v18.6 "Leia" (Aeon MQ 8 Multi-Mod v2.9.0) running on Windows 10/Amazon Fire TV Cube
Youtube Channel
(2019-05-13, 14:03)AleksandarLS Wrote: @dchurch595
Yes, I have been in music from the start but it doesn't show up in views, I can see the view in movies and I can click the tab on to green to make it available for a view in music, but when I scroll through views it is not there as an option to see.
@latts9923 I just noticed something today with the resume indicator. Last night I was watching a TV show episode and it said I reached 80%, but when I came back to it this morning that indicator is no longer there. However, if I press play on it, I then get the context menu popup with the option to resume. What's strange is that I also have another TV show episode in progress and it says that I am at 19%. Is this a bug in the code?
Here is an image to try and show what I am referring to.
Imagea gas station nearby
Thanks for your assistance,
Shedrock
@shedrock
I'll take a look. It may be that 80% viewed is displayed as watched.
Youtube Channel
(2019-05-16, 15:12)latts9923 Wrote: @shedrock
I 1st thought that, but then I realized in my advancedsettings.xml file, I have it set to 98%. I will check it again though. Thanks for getting back to me.
Shedrock
  • 101
  • 102
  • 103(current)
  • 104
  • 105
  • 140
  • 13 Vote(s) - 4.54 Average
Aeon MQ 7 Leia Mod4.5413
