Nickerw
Hmm...try removing the repo zip file from Kodi/addons/packages and try to install it again. Thanks for pointing out the HTTP warning...I thought I had fixed that on the last repo update. I'll see if I can reproduce your full screen music problem.
Kupo91
I still haven't purchased an Android box to test LibreELEC, but I will at some point. I'll fix the temperature font. I'll take a look at the second weather icon...so far I am unable to reproduce the problem. I'll take a look at removing the RCB skin files.
MB1968
Have you installed the latest
Visual C++ Redistributable?
nomnom27
The control is there, but I forgot to add the Right List view to the visible line of the radio button. To fix it until I can post another update, open the file IncludesTopMenu.xml and find
xml:
<control type="radiobutton" id="19206">
<include>TopMenuRadioButton</include>
<label>Show Cast</label>
<onclick>Skin.ToggleSetting(showCast)</onclick>
<selected>Skin.HasSetting(showCast)</selected>
<visible>Control.IsVisible(74)</visible>
</control>
Change the line
xml:
to
xml:
<visible>Control.IsVisible(51) | Control.IsVisible(74)</visible>
Then open the file ViewsRightList.xml and find
xml:
<control type="image">
<left>1100</left>
<top>313</top>
<height>512</height>
<width>512</width>
<aspectratio aligny="bottom">keep</aspectratio>
<texture background="true">$INFO[Container(345).ListItem.Icon]</texture>
<fadetime>FanartCrossFadeTime</fadetime>
<visible>Container.Content(movies)</visible>
<animation type="Conditional" reversible="true" condition="Control.HasFocus(9915)">
<effect type="slide" start="0,0" end="-150,0" time="300" tween="cubic" easing="out" />
<effect type="fade" start="100" end="0" time="200" />
</animation>
</control>
Change the line
xml:
to
xml:
<visible>Container.Content(movies) + Skin.HasSetting(showCast)</visible>
@"chrissix"
That's a good idea to make a button to switch between actress, characterart, or off.
