(2019-08-08, 10:40)Nickerw Wrote: (2019-08-08, 10:38)Nickerw Wrote: (2019-08-05, 10:58)Nickerw Wrote: I tried, but get the message: "Installation from zip-file failed" What happened?
The zip file mentioned above seems to be corrupt. I sownloaded it from here: https://kodi-addons.club/addon/repository.marduk/ and it works properly.
I tried to download the zip from the
link above, but it didn't do anything. Not sure what was happening there.
For anyone STILL having issues getting the Marduk repository, here's what I finally ended up doing.
I downloaded the zip from from the
link latts9923 provided on comment
1657 / page 111. If you use this link,
Marduk's Repo, it should automatically start the download of the zip file for you and save a step.
Unfortunately, you can't install from THAT zip file, so, I then expanded the zip file into my Local Install Source, so that it was a folder named repository.marduk-master
I then installed Marduk's repo by going into that folder, then under another folder named repository.marduk and then using the repository.marduk-1.0.3.zip
The other alternative is to just open the zip and drill down to repository.marduk-master\script.skin.helper.skinbackup\script.skin.helper.skinbackup-1.0.21~alpha.zip and then copy the script.skin.helper.skinbackup folder into your Kodi\Addons folder, overwriting the old version.
Hopefully that'll help those that have drilled through all the posts and still aren't having any luck.
As a side-note, updating the skinbackup program made no difference with colored font issue I mentioned in comment
1704 on page 114. As I said, not a big deal, but wanted to make sure I was as up-to-date as possible before calling it a "bug".
