Hello,
I have some problems with showing the back cover art when I play music in full size sreen.
I am using the last display option ( I guess it is called Option 8 3D) where the front cover is shown and the back cover will be display after some time.
The front cover works but when the back cover comes in there will always be only a list with the song titels.
I have tagged the front cover with the files but how can I show the back covers?
Thanks for your help!
I have always wanted to be able to see to see the movie / tv show name on the rotating fanart, on the main menu. You see a random background popup, and think, "What movie is that?". Then I remember reading somewhere that it had been implemented in Kodi. As I started messing around with the new version, and some of the different skins, I remember seeing it and being very happy.
However, as I've been creating my new Kodi build, using the MQ 7, skin I realized that it wasn't showing up. Did some research today, and, with a little experimentation, I found that it is available on the Aeon Nox: Silvo skin.
It's an option under Skin Settings / Home Window named Display Background Name (Display title of movie/tvshow/artist on home screen if the background has a fanart slideshow as background). There doesn't appear to be any option to change the location of the name though, which, to me, would be better located in one of the upper corners.
If this is possible under MQ7, then I'm definitely missing it.
So, is this already an option, that I have, somehow, missed, or is it something that could be added?
On the Home screen menu there TV shows, episode counts and under music and movies there are counts. How can I make counts appear under concerts?
Is there also a simple way to make counts for categories I add to main home screen menu such as: Radio & count, Surround sound & count (which are all video files) ?
I know it would involve adding variables and counting code.....
Thank you,
Paul
The O Man
