(2020-01-22, 15:41)latts9923 Wrote: @Kupo91
I did not try importing the nfo. Is that where you are seeing the problem?
Ye maybe that makes the difference.. I will tell you what I've done
I usually scrape my movies and tv shows with Ember Media Manager to store all the nfos and artworks on my hdd.
Now I've edited some nfos of those 4 tv shows which I've mentioned before and to refresh them in kodi I ...
1. temporary moved these tv shows in a different folder on my hdd
2. cleaned my library in kodi to remove them
3. moved them back to their original folder
4. went in to my tv show library and clicked 'update library' to reimport them
And then it just imported 1 of 4 tv shows.
I repeated this process like 3 times but always with the same result
Oddly I never had issues doing this before. I always do this if I want to refresh some data.
Then I tried it in Estuary and it worked instantly.
