  • 134
  • 135
  • 136(current)
  • 137
  • 138
  • 210
v18 Aeon MQ 7 Leia Mod
@latts9923
Thank you. All of your work on these mods is very much appreciated!
@latts9923
I have reinstalled my PC, so I did a fresh install of Kodi and wanted to put MQ7 back on..
When I try to install it, I get a message saying that it failed.
In the log, I see this.
ERROR: Failed to move new addon files from 'C:\Users\ssmith\AppData\Roaming\Kodi\addons\temp\52f5b72c-7d46-4cf6-b650-bcf184663570' to 'C:\Users\ssmith\AppData\Roaming\Kodi\addons\skin.aeonmq7.leia.mod'
Would you have any idea how to fix this? I am not sure what its trying to move, all the dependant addons are installed according to the list.
@wags1
You're welcome!
@SteveSmith
Try removing the skin's zip file in Kodi\addons\packages, remove the folder Kodi\addons\skin.aeonmq7.leia.mod if it exists and then try downloading the skin again.
Hi @latts9923 there is an issue with Up Next and some people think its skin related. Can you have a look on this?
https://forum.kodi.tv/showthread.php?tid...pid2918226
@Kupo91
Sure, I'll take a look at it.
(2020-03-03, 19:51)latts9923 Wrote: @Kupo91
Great, thank you Smile
@latts9923 In my TV shows I have different fanarts for all seasons. So if I open a TV show each season has its own background. But I just noticed if you open one of the seasons its not showing the background of the season but the background of the whole TV show. Is this intended or is this a bug?
@Kupo91
The season fanart is working for me. Which view are you using?
(2020-03-08, 13:37)latts9923 Wrote: @Kupo91
I'm using the Panel view.
This is what my fanart of the TV show Lost looks like:
When I open the TV show, this is what my fanart of Season 1 looks like:
And when I open Season 1.. it shows the fanart of the TV show instead of Season 1
How do I turn off or on actress art when I'm in Movies Info?
(2020-03-08, 23:13)Kupo91 Wrote: I'm using the Panel view.
Season fanart enabled in the topmenu in the episodes window?
Windows 11 Pro
Kodi 21 - Aeon MQ7/MQ9 Omega Mod
Kodi 20.5 - Aeon MQ9 Nexus Mod
Android - Beelink GT King
Kodi 21 - Aeon MQ7 Omega Mod
Kodi Maven Fork 21 - Aeon MQ9 Omega Mod
CoreELEC - Beelink GT King
@melons2
I'm at work so I can't confirm, but I'm pretty sure it's tied to the Actress button in the Top Menu for the Right List View.
(2020-03-11, 19:22)latts9923 Wrote: @melons2
I'm sorry but I still can't find it.
Let me know when you have more time to look at this.
I'm in no big hurray.....
@melons2
I was wrong, the setting is in the Top Menu under "COLLECTION/CHANGE VIEW" and it's called "DIALOGUE ACTRESS ART". It's not tied to the Right List View.
(2020-03-12, 04:35)latts9923 Wrote: @melons2
Thank you!
  • 134
  • 135
  • 136(current)
  • 137
  • 138
  • 210
Aeon MQ 7 Leia Mod13
