All the channels stream on simple pvr, just no recording. I have added a snippet of log into last post.
I mean "IPTV Recorder".
Can you see the programs in "Channel Groups \ All Channels"?
Can you go into a program and play a channel with "Play Channel"?
2018-06-18, 14:52
(This post was last modified: 2018-06-18, 14:57 by brumbie.)
Yes I can play the channels in the IPTV Recorder.All the channels are listed.
<settings>
<setting id="add.context.searches" value="true" />
<setting id="add.favourite.channel" value="true" />
<setting id="debug" value="false" />
<setting id="debug.ffmpeg" value="false" />
<setting id="external.m3u.1" value="0" />
<setting id="external.m3u.2" value="0" />
<setting id="external.m3u.file.1" value="" />
<setting id="external.m3u.file.2" value="" />
<setting id="external.m3u.url.1" value="" />
<setting id="external.m3u.url.2" value="" />
<setting id="external.player" value="" />
<setting id="external.player.args" value="-fs" />
<setting id="external.player.watch" value="false" />
<setting id="external.xmltv.1" value="0" />
<setting id="external.xmltv.2" value="0" />
<setting id="external.xmltv.file.1" value="" />
<setting id="external.xmltv.file.2" value="" />
<setting id="external.xmltv.url.1" value="" />
<setting id="external.xmltv.url.2" value="" />
<setting id="ffmpeg" value="C:\Ffmpeg\ffmpeg-20180617-bd47cca-win64-static\bin\ffmpeg.exe" />
<setting id="ffmpeg.args" value="" />
<setting id="ffmpeg.ext" value="ts" />
<setting id="ffmpeg.recordings" value="D:\Downloads\kodi downloads" />
<setting id="filename.urlencode" value="true" />
<setting id="hide.channel.name" value="false" />
<setting id="last.update" value="1529323376.23" />
<setting id="m3u.regex.replace" value="" />
<setting id="m3u.regex.search" value="" />
<setting id="minutes.after" value="1" />
<setting id="minutes.before" value="1" />
<setting id="multiline" value="true" />
<setting id="post.command" value="" />
<setting id="python" value="pythonw.exe" />
<setting id="recordings" value="D:\Downloads\kodi downloads\" />
<setting id="refresh" value="false" />
<setting id="scroll.ms" value="2000" />
<setting id="scroll.now" value="true" />
<setting id="service" value="true" />
<setting id="service.delay.seconds" value="60" />
<setting id="service.interval" value="6" />
<setting id="service.startup" value="true" />
<setting id="service.time" value="03:33" />
<setting id="service.type" value="0" />
<setting id="show.categories" value="false" />
<setting id="show.finished" value="true" />
<setting id="show.now.next.all" value="false" />
<setting id="show.now.next.favourites" value="true" />
<setting id="show.now.next.hide.empty" value="false" />
<setting id="show.now.next.lists" value="false" />
<setting id="silent" value="false" />
<setting id="sort.channels" value="true" />
<setting id="task.scheduler" value="false" />
<setting id="version" value="0.0.65" />
<setting id="view.mode" value="" />
<setting id="xmltv.title.regex.replace" value="" />
<setting id="xmltv.title.regex.search" value="" />
</settings>
Zip up the contents of
userdata\addon_data\plugin.video.iptv.recorder
and pm me a link to it on Google Drive or somewhere similar and I'll see if I can see what is wrong.
Hi. I think you might need to remove the stream links from your post. I'm not sure how legal they are. Kodi are allergic to lawyers.
You need an xmltv file.
It contains all the program times and channels.
Your tvg-id attributes need to match your xmltv "channel id" values when you find your xmltv file.
I think the tvg-names need to match the "display-name" too. I can't remember off-hand if they do now. A lot has changed recently due to people's requests on here.
2018-06-20, 20:46
(This post was last modified: 2018-06-20, 20:46 by DarrenHill.)
Indeed - posting of iptv stream links isn't allowed here.
They have been removed.
Oh sorry about the stream links and thank you for removing them.
Any chance of recording without an xml file though? That would be handy
