2018-03-26, 00:56
I'm testing my addon on v18 and found a strange difference between ARM 32-bit OS and other OS's (Windows/OSX/Linux x86) with normal fileIO.
Here's my test Code:
Android v7a log:
OSX Log
Any old test zip file will have the same issue (my test file was just two text files zipped up). This did not previously occur in v17.6 that I'm aware of. Is there a difference in v18 now that would account for this change?
python:
print 'This is a file test'
import zipfile
with open(os.path.join(get_userdata_temp_dir(),'Test_File.zip'),'rb') as content_file:
content_file.seek(0,2)
print content_file.tell()
print zipfile.is_zipfile(content_file)
Android v7a log:
xml:
22:48:06.681 T:18446744072283060448 NOTICE: special://profile/ is mapped to: special://masterprofile/
22:48:06.681 T:18446744072283060448 NOTICE: -----------------------------------------------------------------------
22:48:06.682 T:18446744072283060448 NOTICE: Starting Kodi (18.0-ALPHA1 Git:20180308-d366eb4). Platform: Android ARM 32-bit
22:48:06.682 T:18446744072283060448 NOTICE: Using Debug Kodi x32 build
22:48:06.682 T:18446744072283060448 NOTICE: Kodi compiled Mar 8 2018 by Clang 5.0.300080 for Android ARM 32-bit API level 21 (API level 21)
22:48:06.682 T:18446744072283060448 NOTICE: Running on amlogic MXQ pro+ with Android 5.1.1 API level 22, kernel: Linux ARM 64-bit version 3.14.29
22:48:06.682 T:18446744072283060448 NOTICE: FFmpeg version/source: 3.4.1-Kodi
22:48:06.682 T:18446744072283060448 NOTICE: Host CPU: AArch64 Processor rev 4 (aarch64), 4 cores available
22:48:06.683 T:18446744072283060448 NOTICE: Product: p201, Device: p201, Board: p201 - Manufacturer: amlogic, Brand: Android, Model: MXQ pro+, Hardware: amlogic
22:48:06.687 T:18446744072283060448 NOTICE: External storage path = /storage/emulated/0; status = ok
22:48:06.687 T:18446744072283060448 NOTICE: ARM Features: Neon enabled
22:48:06.688 T:18446744072283060448 NOTICE: special://xbmc/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
22:48:06.688 T:18446744072283060448 NOTICE: special://xbmcbin/ is mapped to: /data/data/org.xbmc.kodi/cache/apk/assets
22:48:06.688 T:18446744072283060448 NOTICE: special://xbmcbinaddons/ is mapped to: /data/app/org.xbmc.kodi-2/lib/arm
22:48:06.688 T:18446744072283060448 NOTICE: special://masterprofile/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/userdata
22:48:06.688 T:18446744072283060448 NOTICE: special://envhome/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files
22:48:06.688 T:18446744072283060448 NOTICE: special://home/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi
22:48:06.688 T:18446744072283060448 NOTICE: special://temp/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
22:48:06.688 T:18446744072283060448 NOTICE: special://logpath/ is mapped to: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp
22:48:06.689 T:18446744072283060448 NOTICE: The executable running is: /data/app/org.xbmc.kodi-2/lib/arm/libkodi.so
22:48:06.728 T:18446744072283060448 NOTICE: Local hostname: 192.168.1.14
22:48:06.729 T:18446744072283060448 NOTICE: Log File is located: /storage/emulated/0/Android/data/org.xbmc.kodi/files/.kodi/temp//kodi.log
22:48:06.729 T:18446744072283060448 NOTICE: -----------------------------------------------------------------------
22:48:06.777 T:18446744072283060448 NOTICE: load settings...
22:48:07.206 T:18446744072283060448 NOTICE: ADDON: xbmc.python v2.25.0 installed
22:48:30.017 T:18446744072304996032 DEBUG: This is a file test
22:48:30.023 T:18446744072304996032 DEBUG: 2
22:48:30.023 T:18446744072304996032 DEBUG: False
OSX Log
xml:
13:59:15.991 T:140735181774848 NOTICE: -----------------------------------------------------------------------
13:59:15.991 T:140735181774848 NOTICE: Starting Kodi (18.0-ALPHA1 Git:20180308-d366eb411a). Platform: OS X x86 64-bit
13:59:15.991 T:140735181774848 NOTICE: Using Debug Kodi x64 build
13:59:15.991 T:140735181774848 NOTICE: Kodi compiled Mar 8 2018 by Clang 9.0.0 (clang-900.0.37) for OS X x86 64-bit version 10.8.0 (1080)
13:59:15.992 T:140735181774848 NOTICE: Running on Apple Inc. MacBookPro12,1 with OS X 10.11.6, kernel: Darwin x86 64-bit version 15.6.0
13:59:15.992 T:140735181774848 NOTICE: FFmpeg version/source: 3.4.1-Kodi
13:59:15.992 T:140735181774848 NOTICE: Host CPU: Intel® Core i5-5257U CPU @ 2.70GHz, 4 cores available
13:59:15.992 T:140735181774848 NOTICE: special://xbmc/ is mapped to: /Applications/Kodi_Retroplayer.app/Contents/Resources/Kodi
13:59:15.992 T:140735181774848 NOTICE: special://xbmcbin/ is mapped to: /Applications/Kodi_Retroplayer.app/Contents/Resources/Kodi
13:59:15.992 T:140735181774848 NOTICE: special://xbmcbinaddons/ is mapped to: /Applications/Kodi_Retroplayer.app/Contents/Resources/Kodi/addons
13:59:15.992 T:140735181774848 NOTICE: special://masterprofile/ is mapped to: /Users/XXX/Library/Application Support/Kodi/userdata
13:59:15.993 T:140735181774848 NOTICE: special://envhome/ is mapped to: /Users/XXX
13:59:15.993 T:140735181774848 NOTICE: special://home/ is mapped to: /Users/XXX/Library/Application Support/Kodi
13:59:15.993 T:140735181774848 NOTICE: special://temp/ is mapped to: /Users/XXX/.kodi/temp
13:59:15.993 T:140735181774848 NOTICE: special://logpath/ is mapped to: /Users/XXX/Library/Logs
13:59:15.993 T:140735181774848 NOTICE: special://frameworks/ is mapped to: /Applications/Kodi_Retroplayer.app/Contents/Libraries
13:59:15.993 T:140735181774848 NOTICE: The executable running is: /Applications/Kodi_Retroplayer.app/Contents/MacOS/Kodi
13:59:15.993 T:140735181774848 NOTICE: Local hostname: .local
13:59:15.993 T:140735181774848 NOTICE: Log File is located: /Users/XXX/Library/Logs//kodi.log
13:59:15.993 T:140735181774848 NOTICE: -----------------------------------------------------------------------
13:59:16.003 T:140735181774848 NOTICE: load settings...
13:59:16.181 T:140735181774848 NOTICE: ADDON: xbmc.python v2.25.0 installed
15:44:42.743 T:123145305063424 DEBUG: This is a file test
15:44:42.744 T:123145305063424 DEBUG: 53602
15:44:42.744 T:123145305063424 DEBUG: True
