2018-03-28, 19:41
As of Krypton, the context menu from the songs pane (list id=100) is not available. The upshot is that there is no way to reorder tracks using a remote.
(2018-05-11, 00:04)nonJon Wrote: Edit: Would someone kindly move this to the dev forum?Anything music library related is best here - this subforum covers both user support and music library fixes and new feature design.
(2019-10-16, 18:22)nonJon Wrote: Bump. Issue opened on GitHub. Hopefully this won't slip thru the cracks of another release.
(2020-11-21, 08:01)purpleomega Wrote: Im using 18.9 on a windows 10 machine and can't edit playlists.Use the keyboard to edit the playlist. See reorganise items in sect 4.2 here... https://kodi.wiki/view/Basic_playlists
(2018-03-28, 19:41)nonJon Wrote: As of Krypton, the context menu from the songs pane (list id=100) is not available. The upshot is that there is no way to reorder tracks using a remote.Yeap, and it has taken ages for me to figure out what broke this functionality and made the playlist editor useless unless you have a keyboard attached and the intuition to know what keys to hit.
(2020-11-29, 15:14)DaveBlake Wrote: And low it was so....Have to admit other than in skin testing have never used that.
Music playlist editor has received some attention, the bugs have been fixed and is hopefully now even a little better than before. Thanks to https://github.com/xbmc/xbmc/pull/18838 and https://github.com/xbmc/xbmc/pull/18852
Fixes will be in v19 beta 2 (and nightly builds from tonight)
