I was wondering if there is an add-on to add Blu-ray case s to the movie posters, I saw some YouTube videos and emby also have it.
DaVu
Team-Kodi Member
Inside Kodi that option depends on the skin. IIRC for AeonMQ you need to have the word "bluray" somewhere in the path to the movie file to show up bluray-cases in library view.
If the skin does not support that, you are out of luck.
Not sure how emby does it.
I Have Blu-Ray In My File Names But Can't Seem To See Blu-Ray Cases Since Showcase In The Old Days Of Aeon
Thanks, Learned To Live Without It..
Long Live XBMC/KODI
Plenty of skins will do this for you, take mine Aeon Madnox, if you activate cases in the various views then it will mainly use video resolution of the file to assign the relevant case. Lots of skins have cases but you need to activate them and possibly other options in the skin to actually have the cases appear.
SKIN: Aeon Madnox
RIP Schimi2k, we miss you.
When I grow up I want to be a skilled skinner
Thank me by ⬇ adding to my + reputation
